water/methanol injection kit
Old Aug 18, 2007 | 03:16 PM
6.0superduty's Avatar
6.0superduty
Hi everybody, I was recently talking to a good friend of my dad the other day and we got to talking about water/meth injection for my 04 6.0 turbo diesel. He said that he has made plenty of homeade injection kit for different vehicles over the years. He said to get a tank that can stay sealed and withstand the 30lbs of boost that my truck makes. Then run a line from the pressure side of the turbo system into the top of the tank. Then run another line from the bottom of the tank back into the suction side of the turbo system with a nozzle on the end. He said the boost pressure from the turbo pressurizes the tank and forces the water/meth into the intake tube. It sounds pretty clever to me. The only questions I have are, what nozzles should I get and will running the water/meth mix through my turbo hurt it? I ave an SCT tuner and my truck makes about 475hp and about 800ftlbs. What kinf of flow do I need when I will only be using 30lbs of boost? Thanks for your help in advance.
Old Aug 18, 2007 | 08:59 PM
6L PWR's Avatar
6L PWR
For one, you want the nozzle as close to the engine as possible or else it runs the risk of puddling. Also, you want to be able to shut it off 5 minutes before you turn off the truck for the same basic reason. As for pressure, 30LBS?!?! Look into the kits. I've got the Snow Performance Stage III system. The pump is 150PSI pump!! You NEED to make a fine mist for it to work efficently.
Old Aug 18, 2007 | 09:46 PM
FTE Herman's Avatar
FTE Herman
Also, take a look at this forum's sponsor: http://www.alcoholinjectionsystems.com/ I'm spack dab in the middle of installing one of their kits right now. I think you might find that a system that is tunable will perform over a greater range of operating conditions, which I expect apply to your application. Make sur eyou get a big[ger] tank as you are in the boost more frequently.
Old Aug 19, 2007 | 11:39 AM
6.0superduty
Thanks guys. I didn't know much about injecion. I was just curious if that would actually work.
Old Aug 20, 2007 | 07:07 PM
AIS's Avatar
AIS
If you have any specific questions feel free to give us a call or PM us. We'll be happy to help you out.
Old Aug 20, 2007 | 07:27 PM
6.0superduty
Thanks, Ill lokk into you guys in a month or so. Gotta get new exhaust first.
Old Oct 1, 2007 | 10:27 AM
993/4ton's Avatar
993/4ton
I have heard really good things about the DevilsOwn water injection systems. They have some really nice kits and their tech support is outstanding!
Old Jan 27, 2011 | 01:47 PM
ace4's Avatar
ace4
Which system would be the best to buy
logger1989
Nov 27, 2014 06:28 PM
Y2KW57
26
Sep 20, 2014 09:48 PM
61steven
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jul 18, 2014 12:43 AM
91 Dually
Oct 17, 2013 02:18 PM
91 Dually
Sep 30, 2013 10:58 PM
