1998 Ford Explorer good or bad
Old Aug 17, 2007 | 09:48 PM
lloyd miiller's Avatar
lloyd miiller
I am thinking of purchasing a 1998 explorer for comuting. It already has 100000+ miles on a 4.0L with automatic. It seems to be a solid vehichle but I have no experience with explorers. Any opinions or advice is welcome. I think I can purchase for around 3000.00
Old Aug 17, 2007 | 10:06 PM
quicklook2's Avatar
quicklook2
a little more info would help.
2wd or 4wd?
take it to a mechanic, pay 50 bucks or so and have them go over it.
check kbb.com for a price quote.
Old Aug 17, 2007 | 10:53 PM
mrshorty's Avatar
mrshorty
Which 4.0: OHV or SOHC? OHV is a pretty solid engine with few complaints. SOHC is OK, you just need to watch the chain tensioners.
Old Aug 17, 2007 | 11:28 PM
Ed21's Avatar
Ed21
I've got 125k on mine and it's still going strong with no major problems.
The sepentine belt broke the other day, but it may or may not have been the original. So I chalk that up to poor maintnence on my part. I do try to maintain it though. That one fell through the cracks.
I got it at 35k miles. 4.0 sohc 4wd. A solid performing engine.
I tow my 16' boat with ease. I once towed a 26' cabin boat about 10 miles on flat ground. Way over weight & a bit scary, but nothing broke. I won't do it again though.
17mpg come rain or shine.
Old Aug 18, 2007 | 04:39 AM
marragtop's Avatar
marragtop
Make sure you drive it when the engine is cold and make sure the trans shifts properly. Also, if it is 4wd or awd, make sure it works. If you are buying from a dealer, make them run a carfax report on it. Things to avoid are auctioned or leased cars, collisions, and questionable odometer readings. If everything checks out ok, 3k is a good price.
Old Aug 18, 2007 | 12:08 PM
Space Truckin''s Avatar
Space Truckin'
I really like my '98 XLT 4.0L SOHC 4WD. I just changed all the timing chains, tensioners, and guides at 148K miles. It was a very big job but had to be done and was worth the trouble. Just include the repair cost in your budget for purchasing the vehicle and you won't have any problems. I wouldn't buy one with the 4.0L OHV. That engine may not have the timing chain problem but that doesn't change the fact that it is a bit of a dog. The 4.0L SOHC is much better (power and MPG) as long as you budget for the timing chain tensioners and guides update.
Old Aug 20, 2007 | 01:31 PM
bulldog3531's Avatar
bulldog3531
I have a 98 4.0 SOHC 2wd with 120,000 miles on it. Still running strong. Just do you regular maintenance and it will last. One thing to ask is to see if they have the maintenance history to see what has been doen or not done to the vehicle.
drifter
94
Sep 27, 2019 02:13 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Aug 3, 2016 08:37 AM
Sweeper
Feb 11, 2009 01:15 AM
Bob Cook
Dec 14, 2006 03:03 PM
Jimmyk
Jan 10, 2005 09:54 PM
