Brake light on dashboard
Old Jul 18, 2007 | 08:34 PM
tnystuen's Avatar
tnystuen
On the dashboard my brakelight comes on and is now staying on. The emergency brake is not on nor any tail lights to indicate my brakes might be on.
Could this be a short somewhere?
Thanks in advance
Tracie
Old Jul 19, 2007 | 08:32 AM
ubereal2's Avatar
ubereal2
Check the brake fluid level. If it's full, tap on the side of the resivour. The floating switch may be stuck, telling you that you're fuid level is low.
Old Jul 19, 2007 | 09:48 AM
frankenherder's Avatar
frankenherder
This happened to me too, rear pads were so low it was giving a false reading since it was triggering the e-brake sensor. i would get your rear brakes looked at ASAP.
Matt
Old Jul 19, 2007 | 11:14 PM
Space Truckin''s Avatar
Space Truckin'
These are both good ideas. Find the problem before you drive! You can safely ignore the ABS light but not the standard brake light. If the e-brake is off, the light means you have low brake fluid preasure. You could easily be putting yourself or others in danger.
Old Aug 2, 2007 | 10:09 PM
tnystuen's Avatar
tnystuen
thank you I am on the way to Les Schwab tomorrow
Old Aug 20, 2007 | 01:57 PM
tnystuen's Avatar
tnystuen
Update on Brakes display light
I took the truck to Les Schwab, they said they brakes looked fine. The sensor by the side of the oil underneath hood was ok
The day before I took it to LesSchwab, I was on a really steep hill and pushed in the ebrake as far as I could to really let go. I mean release it good and well. I had done this many times before thinking that might have been the problem
The display came off and was not showing when I went to Les Schwab.
Thanks guys
SpencerS
13
Feb 4, 2017 10:33 PM
sseebart
20
Feb 22, 2015 10:51 AM
JKLeary
Apr 21, 2014 08:58 AM
1991F-150BLK
Feb 28, 2011 02:39 PM
DanL.
Aerostar
Apr 20, 2000 05:36 AM
