Sponsored by: Real Truck
Brake problem! . . . what is it?
Old Aug 17, 2007 | 03:52 PM
live2hunt's Avatar
live2hunt
'01 F-350 SD w/ PS. Just today, out of nowhere and with no warning, I applied brake and the pedal went to the floor! At first touch of the pedal it felt like there would be normal brake but immediately softened and pedal went to the floor. Still barely had enough brake to not hit somebody. Drove home (gingerly) and have been scratching my head. Fluid is normal.
What could it be? And how do I know?
Old Aug 17, 2007 | 03:56 PM
redford's Avatar
redford
FTE Leadership Emeritus
If the fluid level is normal, you probably need a new master cylinder.
They usually don't go bad at once, you might first notice that when you're stopped at a stoplight, the pedal might "sink" slowly after you stopped.
Old Aug 17, 2007 | 04:40 PM
live2hunt's Avatar
live2hunt
Brake Update!
I found the problem (area). RR caliper has fluid running out of it. ??!!*^#!?
Is it possible that the pads can get so low that fluid leaks out of the pistons?
Old Aug 17, 2007 | 05:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
No but a blown piston seal will cause it.
You gonna rebuild or replace?
Now is a great time to replace all the fluid!
Old Aug 17, 2007 | 05:38 PM
redford's Avatar
redford
Yea, the sudden "to the floor" symptom usually means you're leaking fluid somewhere. That's why the "fluid level is good" statement kind of puzzled me.
Like Monsta said, replace the brake fluid whle you fix the problem. Make sure you look at the other rear caliper also.
Christof13T
Nov 24, 2012 06:39 PM
Pro DIY
Jan 28, 2012 06:28 AM
tbm3fan
Nov 2, 2006 08:11 PM
wildcard30
2004 - 2008 F150
Jun 5, 2006 09:19 PM
