Replacing trans pan gasket...
Old Aug 17, 2007 | 01:23 PM
Fordpup's Avatar
Fordpup
Question Replacing trans pan gasket...
Hey guys... I did a tranny service about 1000 miles ago on my 89 F-150, 302, AOD. The generic gasket that came with the filter has leaked since day two...I'm looking to replace it with a FelPro gasket. Should I use some sort of form-a-gasket sealer with this gasket to assure me of a good seal? I don't want to go thru this again for a long time.
Thanks in advance.....
Old Aug 17, 2007 | 02:25 PM
blue68f100's Avatar
blue68f100
Some transmission only require a rtv seal. If you use a gasket, I only use sealant on the part (pan) being removed. This makes cleanup a lot easier.
I have never had a pan leak that only required the RTV sealant. Most gaskets over a period of time will start to seep. The main reason gaskets leak are due to over tightening, and the pan not being flat.
Old Aug 17, 2007 | 03:26 PM
Fordpup's Avatar
Fordpup
Ok.... Sealant on pan only, check pan to see if it is flat. I have a straight edge for that.
Thanks, that's first on my to-do list for Saturday.
Old Aug 17, 2007 | 03:46 PM
blue68f100's Avatar
blue68f100
I like laying them on a flat surface. This way you can see if the lip is bend down where someone may have pried off. If you decide to use it on both surfaces, it takes a long time for the transmission to stop dripping fluid. Which makes it real hard to seal. Felpro makes a special pan gaskets for automatics, sealed so the fluid does not seep through. Just don't over tighten. Most only call for around 12-15 in-lbs. torque.
Old Aug 17, 2007 | 04:28 PM
quicklook2's Avatar
quicklook2
do not over tighten bolts.
are you sure the gasket is where it is leaking?
Old Aug 17, 2007 | 08:07 PM
Fordpup's Avatar
Fordpup
Yes, the gasket is definitely leaking. About a week or so ago I tightened the bolts up a bit and the leak slowed, so I figured I'd ask you guys about using sealant this time.
Frankmyers
Feb 10, 2015 09:49 AM
Gigemags05
Dec 21, 2014 10:31 AM
Animal28
Apr 27, 2013 09:36 AM
mike L
Nov 4, 2012 07:35 AM
rotun
Dec 7, 2009 12:15 AM
