Modular V10 (6.8l)
Tough Crank
Old Sep 19, 2002 | 09:40 AM
Jimmy79's Avatar
Jimmy79
Tough Crank
I got a 1999 F 250 4X4 CC Lariat blah blah blah.....It has 78000 miles on , great running, but I had a hard time getting it cranked the other morning....Wasn't cool or anything here, just a little hesitant....Starter went a round a few times and when it did crank I had to hold on the gas to keep it running....I could feel it missing, and then it finally spitterd and sputtered enough to get all cylinders going. Sound like time to get new plgs an wires..If so, any suggestions on a particular kind??? Or if it sounds like something else, could you give me some input???
Jimmy
Alabama
Old Sep 19, 2002 | 12:08 PM
Y2K350's Avatar
Y2K350
Tough Crank
I would go to Ford and get OEM.
2000 F350SD,SRW,RC,5spd man,V10, Front Leveling Kit,4.30 gears, 285/75/16 Wild Country
Old Sep 19, 2002 | 02:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
Tough Crank
>I Sound like time to get new plgs an wires..If so, any suggestions on a particular kind???
Plugs. A good name brand will suffice so long as it is the proper heat-range & size (of course...) Plus, we (V10ers) do not have wires that need replaced. Coil-on-plug ya know!
When is the last time you changed your fuel filter?
Could it be the IAC valve?
Any smoke at start up?
Did it smell heavily of gas?
Old Sep 19, 2002 | 05:14 PM
DJR 17's Avatar
DJR 17
Tough Crank
Maybe a vapor lock? My truck did the same thing about 2 months ago. It only did it one time and it's been fine so far. I am thinking about new plugs but dreading changing them. I bet a new fuel filter wouldn't hurt either..My truck has been knocking too even after going to the mid-grade gas.
1999.5 F-250 V-10 4x4 CC SWB Lariat 3.73
Old Sep 19, 2002 | 06:39 PM
V10man's Avatar
V10man
Tough Crank
It sounds alot like the IAC. I'd start there.
Old Sep 19, 2002 | 08:34 PM
4x4x4x4's Avatar
4x4x4x4
Tough Crank
I concur.
Old Sep 20, 2002 | 08:06 AM
Jimmy79's Avatar
Jimmy79
Tough Crank
Bad question...what's the IAC??? New here
Thanks!!!
Jimmy
Old Sep 20, 2002 | 01:55 PM
mikeking's Avatar
mikeking
Tough Crank
Idle Air Control Valve
Old Sep 21, 2002 | 11:51 PM
BuiltToughF250's Avatar
BuiltToughF250
Tough Crank
