Need more power
Old Aug 16, 2007 | 11:28 PM
shanett306's Avatar
shanett306
Need more power
After installing my 6.0 cooler and loosing 5-6 psi. I've decided i need to do something to recover the lost boost. I originaly thought i would just put on a 99 and up .85 wastgated turbo assembly. Now I'm thinking i should just go for the stage 1 injectors and keep my stock turbo. The bigest problem I have is when the tranny shifts into the next gear while I'm pulling a load it looses so much boost cause the rpms drop so much.
Old Aug 17, 2007 | 09:37 AM
tjbeggs's Avatar
tjbeggs
I think DIY stage 1's and a chip burned for them would be the perfect upgrade. The SD turbo would help with your lag but so will stage 1's. One thing you can do to help with the lag is to move your MAP sensor line to the turbo outlet before the intercooler rather than after the intercooler at the intake plenum. I saw a larger reduction in lag when I moved my MAP line.
Old Aug 17, 2007 | 11:32 AM
c00nhunterjoe's Avatar
c00nhunterjoe
as did i a well worth doing mod
