Dominator 66 Report
Old Aug 16, 2007 | 11:23 PM
fishmanndotcom's Avatar
fishmanndotcom
Dominator 66 Report
well after tying up loose ends and getting the truck back to drivin status i took a few trips around the city... terrorizing the ricers and what not. i have to say it was worth every penny. if nothing else just the fact that i know my turbo isnt going to explode. there is a little more turbo lag but once the turbo spools the truck launches! now i know to a lot of you the D66 is no big deal and there is much bigger and better, but for my use it is perfect. i'm not pulling sleds or draggin against 5.0's, i just tow a lot through the mountains and HATE being passed by tractor trailers.
anyway... i love my truck 10 times as much now and feel better knowing it's longevity has just been extended.
NOW... i gotta get that Banks IC kit in before my long haul coming up in Sept!
thanx for all the help again guys... i knew i could count on you!
-cutts-
Old Aug 17, 2007 | 12:30 AM
RocknXJ's Avatar
RocknXJ
What injectors are you running?
I wonder if it's worth going to a D66 with stock (CA) injectors, or just rebuild the turbo and go to a 1.0 housing.
Old Aug 17, 2007 | 05:49 AM
fishmanndotcom
with stock injectors you wont gain anything. like i said the biggest reason i went to a D66 was the fact it can handle the higher PSI's the bigger injectors force. the only way i would suggest doing a D66 on a stock truck is if the plans are to swap in bigger injectors.
I am running the DIY Stage-I's (160cc) with a Tony Wildman chip (still on the 'stock' programming) and straight pipe exhaust, 6637 intake, gutted EBPV, and shimmed FPR.
-cutts-
Old Aug 17, 2007 | 09:08 AM
tjbeggs's Avatar
tjbeggs
Thanks for the report fishmann. I think the D66 will treat you well.
93f250tn
27
Feb 18, 2015 01:13 PM
El Camino Man
29
Jul 25, 2013 07:16 PM
Shadowrider123
May 1, 2012 06:52 AM
sticks25
41
Jun 23, 2008 01:12 AM
idifamilycab
May 20, 2007 08:03 AM
