Help ID these heads
Old Aug 16, 2007 | 09:38 AM
just-n-time's Avatar
just-n-time
Arrow Help ID these heads
First let me say I have gone threw the listed cylender head ID charts with no success, this is how they are marked.
302 with circle f 2V and below is7M9 and the other is 7M8 then in a circle pattern is 13576 on the out side of the head are two markings one above a bolt hole marked 40 and on one end of the head is the # 255, I have two 302 with out the long casting # like the c8 or c7 and so on,one is not drilled for air injection the other is. Can any one help me to find out the chamber size with out pulling and ccing the heads? JNT
Old Aug 16, 2007 | 03:20 PM
HemiEater's Avatar
HemiEater
you will have to pull the intake to see the numbers and even then it's hard.....
look in the pic to the lower right you can see the (D0OE) you can see this with the intake off and mirror...
Old Aug 16, 2007 | 07:38 PM
just-n-time
Red face Id #
Thank you I will look again.
Old Aug 16, 2007 | 10:36 PM
just-n-time
Well it was just in the very spot you said it would be,my # was C80E, the chart I printed from this forum dose not give just those markings.It shows that another letter like F or K,or L but I dont see it,I did not see it in your picture eather.JNT
Old Aug 17, 2007 | 05:43 AM
HemiEater's Avatar
HemiEater
well you wont see it in the pic cause it's a D0OE head yours are C8OE heads....1968 302 heads with 58cc chambers
Old Aug 17, 2007 | 12:18 PM
just-n-time
how did you arive at 58cc? I am looking at the small blck ford cylinder haed chart, it offers the C8OE to be in the 63cc area,what am I doing wrong?
Old Aug 17, 2007 | 07:50 PM
HemiEater's Avatar
HemiEater
I just looked it up on a few more sites and found it to be any where from 53 to 63 all depends on the last letter ofter the OE. if it has one ......
What makes you think you are doing something wrong?
Old Aug 17, 2007 | 09:09 PM
just-n-time
Ah I see well it only has the 4 item stamp of C8OE
Old Aug 17, 2007 | 09:22 PM
just-n-time
Well I dont realy think I am doing much wrong, but I have not gotten this much in depth with gas burners for quite afew years.and I must be second guessing myself. Like I could not remember the differance in the 02 to the 351 deck hight and width, I kept thinking the holly 4V intake would fit the 51, but it will yet it wont.you know it will bolt up but you have vacuum issues and water port at the front that needs extra goop (sylicone) placed at the matting area. Just little things that this forum has had to jog my mind. well thanks again for the help, I thought I would look up my old formula book to do the compression numbers on this build, once I get the compressed hight of the head gasket I will pull that head to do a cc check. Latter JNT
FX5
Mar 13, 2010 08:35 PM
Lwlandy
Sep 7, 2005 09:10 AM
brucebrey
Jun 30, 2003 01:48 AM
brucebrey
3.8 & 4.2L V6
Jan 30, 2002 10:26 AM
brucebrey
Jan 4, 2002 03:52 PM
