does straight pipes burn valves?
Old Aug 16, 2007 | 09:03 PM
mstrelectrician's Avatar
mstrelectrician
My buddy has a 88 F250 with a 351 and has 2.25 straight exhaust pipes on it. At our local truck pull, A old man told us that would burn valve's is this true?
Old Aug 16, 2007 | 09:19 PM
HemiEater's Avatar
HemiEater
no.........
Old Aug 16, 2007 | 10:00 PM
51dueller's Avatar
51dueller
Maybe on a lawn mower engine.
Old Aug 16, 2007 | 10:12 PM
Conanski's Avatar
Conanski
Potentially... on an engine that cannot correct air mixture for an increase in air flow through the motor.. such as a carb'd motor. An EFI motor has no such problem however.
Old Aug 17, 2007 | 03:37 PM
LxMan1's Avatar
LxMan1
The main reason for burnt valves would either be a lean condition causing extremely high cylinder temps or an exhaust leak at the head. During deceleration, cool air can be drawn back into the cylinder and when cool air hits the hot valve, it cracks. But straight pipes with no exhaust leaks then it will not hurt anything, just sound annoying and crackle alot thru the pipes. I prefer the sound of a good muffler over straight pipes personally.
Old Aug 17, 2007 | 04:48 PM
Kemicalburns's Avatar
Kemicalburns
how long are the strait pipes. if they are dumping by the tcase then i would be a little concerned. but if they are full length of rig should be fine
Old Aug 17, 2007 | 09:29 PM
mstrelectrician
full length exiting behind rear tires
danvhp
1983 - 2012 Ranger & B-Series
Nov 25, 2015 10:20 AM
v10tritanium
Aug 22, 2015 08:59 PM
Oldschoolfordlover86
Apr 12, 2015 08:27 AM
Reaper76
Dec 13, 2013 03:58 PM
fordtruckin
Exhaust Systems
Dec 5, 2002 07:10 PM
