removing wheels...
Old Aug 16, 2007 | 07:00 AM
prisoner of gravity's Avatar
prisoner of gravity
removing wheels...
sort of off topic...but a 7.3 up front...
a 1990 F250 parts truck followed me home... rear wheels have not been off for a long, long time...so far gentle persuasion has no effect...any ideas???
thanks,
Old Aug 16, 2007 | 03:14 PM
roamer37's Avatar
roamer37
Dont be so gentle... use a sledge hammer they will come off..
Old Aug 16, 2007 | 03:21 PM
David85's Avatar
David85
Diddo, and if that doesn't do it, use a torch to heat up the rim where it touches the hub, then wack it some more.
Old Aug 16, 2007 | 04:20 PM
Brimmstone's Avatar
Brimmstone
I had a chain hooked to the rim then to another truck and we had to jerk them off. Even then it took three attempts.
Old Aug 16, 2007 | 05:24 PM
brownieboy525's Avatar
brownieboy525
use a sledge hammer and work your way around the tire it will come off
Old Aug 16, 2007 | 05:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
A good dousing with PB Blaster for a day or so should make them come off much easier.
Ford uses hub centric wheels, so be sure to spray around the hole in the center where the hub sticks through.
