torque specs
lugnuts - 14x1.5 conical seat (if it matters). I searched and found 160 ft/lbs but no one that posted it seemed positive.
the new aluminum rear diff cover - I searched and found two specs. One was like 45 ft/lbs and the other was only like 25 or 26 ft/lbs. Again, this is for the new cover, not the stamped steel one.
I'd just like to know for sure what they are.
Thanks.
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>Torque Specifications </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>lb-ft</TH><TH vAlign=bottom align=middle>lb-in</TH></TR><TR><TD vAlign=top align=left>Axle housing vent</TD><TD vAlign=top align=middle>17</TD><TD vAlign=top align=middle>13</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake cable bracket bolt</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>13</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake cable clamp bolt</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake caliper pin bolts (F-250-350)</TD><TD vAlign=top align=middle>36</TD><TD vAlign=top align=middle>27</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake caliper pin bolts (F-450-550)</TD><TD vAlign=top align=middle>55</TD><TD vAlign=top align=middle>41</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Cast aluminum axle housing cover</TD><TD vAlign=top align=middle>32</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Differential bearing cap bolt</TD><TD vAlign=top align=middle>119</TD><TD vAlign=top align=middle>88</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Differential case half retaining bolts</TD><TD vAlign=top align=middle>122</TD><TD vAlign=top align=middle>90</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Differential pinion shaft lock bolt</TD><TD vAlign=top align=middle>30</TD><TD vAlign=top align=middle>22</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil filler plug</TD><TD vAlign=top align=middle>30</TD><TD vAlign=top align=middle>22</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear axle housing vent</TD><TD vAlign=top align=middle>17</TD><TD vAlign=top align=middle>13</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear spring plate nuts</TD><TD vAlign=top align=middle>251</TD><TD vAlign=top align=middle>185</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Ring gear bolts</TD><TD vAlign=top align=middle>150</TD><TD vAlign=top align=middle>111</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Shock absorber bolts</TD><TD vAlign=top align=middle>63</TD><TD vAlign=top align=middle>46</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stabilizer bar link nuts</TD><TD vAlign=top align=middle>70</TD><TD vAlign=top align=middle>52</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stamped steel axle housing cover bolts</TD><TD vAlign=top align=middle>45</TD><TD vAlign=top align=middle>33</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stone shield nuts</TD><TD vAlign=top align=middle>62</TD><TD vAlign=top align=middle>46</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Traction-Lok® clutch gauge nut</TD><TD vAlign=top align=middle>6.7</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>60</TD></TR></TBODY></TABLE>
