torque specs
Looking for two different torque specs for my 04 F-250...
lugnuts - 14x1.5 conical seat (if it matters). I searched and found 160 ft/lbs but no one that posted it seemed positive. the new aluminum rear diff cover - I searched and found two specs. One was like 45 ft/lbs and the other was only like 25 or 26 ft/lbs. Again, this is for the new cover, not the stamped steel one. I'd just like to know for sure what they are. Thanks. |
Tourque for lugs are 155 f/lbs(haynes).I would like to hear what the diff specs are.I have the new cover waiting to go on too.
If you are going to worry about the proper torque for your diff cover you have too much time on your hands. Just put a bead of sealer around it and tighten the thing down and you will be 'Good to Go'!! This isn't a highly stressed part, it just holds in your gear dope.
This is from an older post I hope this helps clear up the confusion. Also don't forget aluminum cover needs longer bolts. If I remember right they are 1 and 1/4" long 5/16" course thread.
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>Torque Specifications </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>lb-ft</TH><TH vAlign=bottom align=middle>lb-in</TH></TR><TR><TD vAlign=top align=left>Axle housing vent</TD><TD vAlign=top align=middle>17</TD><TD vAlign=top align=middle>13</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake cable bracket bolt</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>13</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake cable clamp bolt</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake caliper pin bolts (F-250-350)</TD><TD vAlign=top align=middle>36</TD><TD vAlign=top align=middle>27</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Brake caliper pin bolts (F-450-550)</TD><TD vAlign=top align=middle>55</TD><TD vAlign=top align=middle>41</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Cast aluminum axle housing cover</TD><TD vAlign=top align=middle>32</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Differential bearing cap bolt</TD><TD vAlign=top align=middle>119</TD><TD vAlign=top align=middle>88</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Differential case half retaining bolts</TD><TD vAlign=top align=middle>122</TD><TD vAlign=top align=middle>90</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Differential pinion shaft lock bolt</TD><TD vAlign=top align=middle>30</TD><TD vAlign=top align=middle>22</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil filler plug</TD><TD vAlign=top align=middle>30</TD><TD vAlign=top align=middle>22</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear axle housing vent</TD><TD vAlign=top align=middle>17</TD><TD vAlign=top align=middle>13</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear spring plate nuts</TD><TD vAlign=top align=middle>251</TD><TD vAlign=top align=middle>185</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Ring gear bolts</TD><TD vAlign=top align=middle>150</TD><TD vAlign=top align=middle>111</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Shock absorber bolts</TD><TD vAlign=top align=middle>63</TD><TD vAlign=top align=middle>46</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stabilizer bar link nuts</TD><TD vAlign=top align=middle>70</TD><TD vAlign=top align=middle>52</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stamped steel axle housing cover bolts</TD><TD vAlign=top align=middle>45</TD><TD vAlign=top align=middle>33</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stone shield nuts</TD><TD vAlign=top align=middle>62</TD><TD vAlign=top align=middle>46</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Traction-Lok® clutch gauge nut</TD><TD vAlign=top align=middle>6.7</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>60</TD></TR></TBODY></TABLE> |
