Safe RPM's for V10
steve reigle
I pull a 28' toy hauler camper. Loaded I am pushing about 11000 pounds and the V10 does pretty good. I have been thinking of trading up in the next year or so to a diesel.
Oh and I have the 3.73 axle also.
Bat
I like this info on the GV....thanks
>What a bunch of light weights. I am running a 32'
>motorhome, pulling a 97 Mazda PU with a combined weight of
>23,000 lbs. My rear gearing is 5.38 although tire size in
>19". Upon buying this unit last summer, I had a Gear
>Vendors auxillary transmission installed. This gives me the
>ability to split the gears. When using the GV, I disengage
>the Ford OD and use the OD of the GV. 3000 rpm gives me 64
>mph which is just fine with me. Last month I averaged 7.1
>mpg over 3,000 miles and all of this with an intermitent MAF
>sensor. It is in the shop at this time getting the sensor
>replaced. Gear Vendors recomends keeping the RPM between
>3000 and 3500, using these rpm's as shift points. Letting
>the Ford transmission do it's own thing is scary, have seen
>4,500 rpm on the freeway maintaing 70 mph. It might do that
>for a long time, but in a motorhome with the engine beside
>you, it is awfully busy sounding.
