What is considered "overheating"
I was towing with my V-10 through southern Nevada and my trusty autometer water temp gauge began reading in excess of 225 degrees! Is this overheating for the V-10? Also the 4r100 tranny fluid got to about 200 degrees. What is considered borderline fluid temps for these assemblies? My truck is a early 1999 V-10 w/ 4r100. Thanks!
Well, I think the engine has a 195* thermostat in it. When I tow, I start to back off around 205 on either the coolant temp, or the cylinder head temp as reported by the PCM thru AutoTap software. 210* would seem really hot to me - that's 15* above spec.
As far as the tranny goes, cooler is better. I was hitting 220 last month, and am looking for ways to drop that because the warmer it gets, the quicker the fluids breakdown.
I would be more concerned about the 225* of the coolant than the 200* of the tranny. But then again, I burned up to GMC 6.5L Turbo Diesels so I'm a bit paranoid on temps.
All of this info is my opinion - other may have more statistically based ideas.
The stock fan, when working correctly is more than enough cooling for the Superduty.
I'd get the truck cool first, before playing around with new toys
I have no idea when the stock one locks up, I've only heard mine come on once, and it was when it was very hot out, and I was idling around pull stumps. The coolant temp never went above 200.
The maximum spec is more like 240F. 195F is just where the thermostat is nominally fully open. It is NOT the maximum temp, it isn't even a relevant temp.
Ford's max on the trans is 220F, with short term (less than 30 minutes) at 250F. This is the temp in the pan or test port. The line to the cooler will be hotter than that.
No, I'm saying you must back off often because you back off at a temperature that is considered normal temps by the auto industry. You're backing of before the cooling fan is even going to be on. The engine and cooling system is designed to go to 240F with NO problems. Let the truck do it's job!
Sorry I didn't mean to get off from the original post.
Now - I'm planning on adding a engine temp gauge, where is the optimal location for it?
240 on an aluminum head engine is quite high.
Mark, I see you've been here since 1999, so I'm not inclined to argue with you much, if at all
But 240? Yeah, with a pressurized system, it won't boil over, but that's still pretty high.
With a 195 thermostat, I wouldn't want to see more than 220, but that's just me And what do I know?
What temp is the fan clutch suposed to lockup at?
Denny
