Back-up light fuse size
Old Aug 15, 2007 | 06:15 PM
biggut's Avatar
biggut
Question Back-up light fuse size
Installing backup lights on my 66 F100. Just wondered if any of you guys could tell me what size fuse is used in the 67-72 back-up light circuit? Thanks, Brett
Old Aug 15, 2007 | 06:43 PM
blue68f100's Avatar
blue68f100
Hate to bust your bubble, but if these are add-on, the factory wiring will not handle the load. Ford used 18ga wire which is very very light duty. I think the tail lights have a 10 amp fuse, for all the lights, I will have to look.
I would recommend that you install a relay and pull the load directly from the battery. I have built a external box that uses transistor instead relays. I ran a 10 ga wire to the back for trailer lights, then used my solid state relays to energize when ever a signal was present. There is nothing like having a short in a trailer and it takes all of your lights except the headlight.
Old Aug 16, 2007 | 02:18 PM
Danger_Dave's Avatar
Danger_Dave
my reverse lights dont even work. sometimes they flash real quick. i should probly fix that, people are dumb and dont realize i am backing up
Old Aug 16, 2007 | 05:36 PM
blue68f100's Avatar
blue68f100
If they flicker, yours may be a simple switch adjustment.
Old Aug 16, 2007 | 07:17 PM
Danger_Dave
where is the switch? ontop of the colomn there is only a sensor for park and neutral
Old Aug 16, 2007 | 08:15 PM
blue68f100's Avatar
blue68f100
Depending on the transmission. It's been 5 yrs since I rebuilt my C6, If I recall it's a detent switch on the side of the transmission.
Old Aug 17, 2007 | 01:03 PM
blue68f100's Avatar
blue68f100
Biggut, I found my fuse box, the backup is a 15 amp. The old fuse box is labeled but is hard to see, black on black. But also powers the rest of the park lights.
btw, you did not say if these were after market or factory.
Old Aug 17, 2007 | 09:38 PM
biggut's Avatar
biggut
They are stock-from a 67. Thanks for the info, I may just wire into the park light circuit.
Old Aug 18, 2007 | 12:31 PM
blue68f100's Avatar
blue68f100
I need to take my no load device apart to see what transistors I used. It's a very simple circuit. Only requires 1 transistor for each circuit. 1 lead for power (from battery fused), 1 for trigger (turn, break...), 1 to external light. If I recalled the transistors were rated at 10amp. So far I have used my original box on 4 different vehicles. So if you have a short on a trailer, it pops the main fuse and not take your truck lights out. Ideal for this very small gaged (18ga) factory wiring, if you pull trailers. When I find it I will post a new thread.
