fuel leak?
Aug 15, 2007 | 03:23 PM
fuel leak?
Hey guys, I've been noticing that my fuel tank is wet with diesel. It's not so bad that its dripping off but it is wet. I was wondering if this is just a normal thing, like an overflow or something. Or should I pull the tank and figure out where the fuel is coming from. If I have to pull the tank, is there any other things I should do at the same time?
Aug 15, 2007 | 04:30 PM
Snowboard season cometh..
Is this all the time or only after filling?
Worst case scenario - i've actually got a 2nd tank that I got for $25 that i'm not using - but let's try and see what's up with yours first
Aug 15, 2007 | 09:34 PM
Could be the hose clamps are loose?
Aug 16, 2007 | 02:03 PM
Any update of this issue deemac?
Aug 17, 2007 | 01:01 AM
I'm not sure if it leaks all the time, its wet all the time but diesel really doesnt evaporate. Sorry for not replying, i've been really busy with work and family.
Aug 17, 2007 | 06:50 AM
Do us a favor:
1. Update your profile - that way we know where you are located
2. Get a glass cleaner that foams and clean off your tank - that will also make it dry
Once your tank is dry, then you can tell if it leaks constantly, or only at fill-ups
Also, does the leak appear to be coming from the front or rear of the tank? Maybe the middle? more on the inside than the outside of the tank?
Get back when you can - we'll be here to help
Aug 17, 2007 | 08:43 AM
You are going to need to put dye in it or something because either your hoses are leaking or the large O-ring seal is leaking or your tank is cracked.
Aug 17, 2007 | 08:46 AM
Where would you be able to pickup some dye for diesel? and would you need to worry about getting dipped?
Aug 17, 2007 | 08:51 AM
NAPA or many auto parts stores.
Aug 17, 2007 | 09:24 AM
Good to know. I'm assuming that it tests differently than the dye used in farm/off-road diesel?
Aug 17, 2007 | 09:29 AM
Aug 17, 2007 | 12:05 PM
I'd guess it's the hose clamp on the fill tube somewhere.
Aug 17, 2007 | 12:19 PM
Quote:
We can sure hope that's it but even if it's a cracked tank, I've got a spare one I wouldn't mind getting out of the shed! That or it's a perfect reason to step up to the 55gal AeroTank replacement unit!!!
JHoffman93
Mar 10, 2013 06:11 PM
hasteranger
Oct 11, 2011 08:23 PM
hasteranger
Oct 4, 2011 07:58 PM
linckeil
Aug 23, 2010 09:43 AM
nodrog
Jul 16, 2008 07:48 PM
