Modular V10 (6.8l)
Low Lock won't work
Old Aug 15, 2007 | 02:57 PM
hydro_37's Avatar
hydro_37
Low Lock won't work
I just tried to use low lock today and it didn't work? 4 wheel drive works fine but no low lock. Was pulling a dump trailer with 3000lbs of gravel and a track loader inside of the trailer. I was very impressed with my V-10's pulling ability. Went to back up, put the truck in 4 low and nothing. $ high worked fine. Any thing to check? Thanks Tim
Old Aug 15, 2007 | 03:08 PM
2000silverbullet's Avatar
2000silverbullet
My truck gets picky going into 4 low at times. I have to make sure I'm completely stopped, truck is in neutral, and brake pedal is pressed firmly... Sometimes it takes me multiple attempts.
Old Aug 15, 2007 | 06:16 PM
dkf's Avatar
dkf
Let me guess you have ESOF.
Sometimes ESOF can be fickle, especially going into low and requires, neutral, movement and time to engage.
Getting out can be a PITA sometimes too.
Thats why I have a manual set-up.
Old Aug 15, 2007 | 11:09 PM
biz4two's Avatar
biz4two
Arrow
2000silverbullet hit it right on the head. Make sure you are stopped in neutral and pressing brake pedal. If you have the ESOF system, then I recommend before putting in 4x4...just get out and put the hubs in the "LOCK" position. Then go ahead and give the 4-LO a try.
Hope this helps...
biz
Old Aug 16, 2007 | 11:12 AM
Big Orn's Avatar
Big Orn
How often do you use 4WD Low? That could be the major factor. ESOF is one of those things - if you don't use it, you lose it....sort of.
Old Aug 16, 2007 | 12:55 PM
Biggziff's Avatar
Biggziff
I cycle the switch each time I drive the truck just to exercise things.
Old Aug 16, 2007 | 01:17 PM
hydro_37's Avatar
hydro_37
Thanks for the replies. I will try them next time I get in the truck. I don't use low lock that often but I use 4X4 at least a couple of times a month. Always at least put the hubs to lock position to lube things up monthly too.
Old Aug 16, 2007 | 04:00 PM
hydro_37's Avatar
hydro_37
Dang I feel really stupid. Just wasn't pushing hard enough on the brake. Thanks to all that replied and hope anyune else that reads this will learn from my experience. Starting to hate the ESOF more and more.
timdidit
Mar 14, 2014 12:42 PM
tim_30043
Modular V8 (4.6L, 5.4L)
Dec 20, 2012 02:20 AM
Tim_in_MD
Jul 9, 2009 06:24 AM
tvvbsn
Jan 20, 2007 05:07 AM
