Injector Rebuild
Old 08-15-2007, 02:05 PM
pngrantham's Avatar
pngrantham
pngrantham is offline
Question Injector Rebuild
Howdy, Does anyone have any info on How to Rebuild a Powerstroke Injector?
What is the most common part to Fail?
Calibration Instructions?
2003 7.3L AD-Injectors.
When performing Injector Buzz Test, 5-7-8 are not as loud as the others.
Cylinder Contribution Test says 8 is not contributing enough.
Thanks in advance
Old 08-15-2007, 02:12 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Are you having performance issues or just basing this off of a test? What was the #8 velocity change? Mine is a LL injector and as it fires right after the 6 it always shows velocity dropoff.
Injector Rebuild DIY sites:
<o>> </o>>
diy injectors
Dpppower injectors
Old 08-15-2007, 02:54 PM
pngrantham's Avatar
pngrantham
At idle, engine runs rough, especially when cold. When it heats up to operating temp, it runs much better, but still has a miss, which gives it a loping sound. I have replaced 3 Injectors so far and it gets better everytime. Before replacing any injectors, it would not start. Now it starts good, but still has a miss.
Old 08-15-2007, 03:00 PM
pngrantham's Avatar
pngrantham
Appreciate the Info, DIY is what I'm looking for. A kit with Instructions. Thanks.
Old 08-15-2007, 04:34 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
Have you tried replacing the under valve cove harness' with the new upgraded harness with the better locking mechanism?
Just a thought before you spend that much money.
Old 08-15-2007, 11:13 PM
pngrantham's Avatar
pngrantham
Yep, Secure Connections
I have secured the connections UVC, with a Quarter without George Washingtons Forehead, It holds pretty snug.
Anymore Suggestions?
Old 08-15-2007, 11:28 PM
Tenn01PSD350
Yep, what are your contribution #s and how were they obtained? How many miles on the truck? You may have a fuel or HPO problem that will not be fixed with injectors. Not saying that is the case but it would suck to replace good parts.
Old 08-16-2007, 10:32 AM
pngrantham's Avatar
pngrantham
Cylinder Contribution and Buzz Test
I use AutoEnginuity. I will run the test in a little while and post the results.
Old 08-16-2007, 11:31 AM
pngrantham's Avatar
pngrantham
Test Results
Buzz Test
1-6-7-8 sound weaker than the others.
Injector Circuit Contribution/Balance Fault
1st 1-6-7-8
2nd 6-7-8
3rd 6-8
4th 6-8
Cylinder Contribution #s on Grid
6=2.1
7=1.8
8=8.2
White Smoke @ 3000rpms
Idle = 717 rpm and ICP = 496psi
Old 08-16-2007, 11:36 AM
pngrantham's Avatar
pngrantham
Truck Specs
2003 F350 7.3L, AutoTrans, Dual Wheel, 137000 Miles, Rapid Flow Cold Air Intake, 4" Stainless Exhaust w/Rapid Flow Muffler. DP Tuner Econo 80 Flash PCM.
Currently have Stock PCM installed.
Old 08-16-2007, 11:43 AM
Tenn01PSD350
Wow. I see what you mean with that #8 stick. Mine shows about 3, + - 0.2 while testing.
Old 08-16-2007, 11:54 AM
pngrantham's Avatar
pngrantham
Whats the difference
Does anyone know the difference between #8 and all the others, besides the Blue Connector.
Old 08-16-2007, 11:59 AM
Tenn01PSD350
It is a Long Lead injector that they began using around 00 or 01 (I think) IOT reduce cackle or knock in the #8 because of the fuel feed design and the firing order. A lot of folks have replaced it with the regular unit.
Old 08-16-2007, 12:58 PM
Tenn01PSD350
Make sure there isn't anything like this going on, photo courtesy of Kwikk:
Old 08-21-2007, 01:43 PM
gearheadz80's Avatar
gearheadz80
gearheadz80 is offline
Who makes a replacement harness besides ford?
Quick Reply: Injector Rebuild
