1991 F-150 Error Codes
Old Aug 15, 2007 | 01:05 PM
Critter183's Avatar
Critter183
I posted this in the Fuel Injection forum, but maybe that was the wrong place for it.
This truck is running very erratically, and I got the following codes:
KOEO:
67 - Neutral safety circuit failure.
CM:
63 - TPS circuit has intermittently failed below minimum 0.6 volts.
33 - EGR valve opening not detected.
29 - Insufficient input from vehicle speed sensor.
Now for my questions.
I cleaned and checked the EGR, seems ok now. I also cleaned and checked the IAC, and it also seems ok. The TPS code, does that indicate a bad TPS? I may replace it just for the halibut.
The 29, speed sensor code, does that indicate the differential mounted sensor for the ABS or the trans mounted sensor? Would that have any effect on the way the engine runs?
Thanks in advance.
Jim
Old Aug 15, 2007 | 07:01 PM
EPNCSU2006's Avatar
EPNCSU2006
I would test the TPS and see if it is actually bad or if there is a loose or poor connection somewhere in the wiring. That can definitely cause the engine to run erratically. The speed sensor used by the computer is the one in-line with the speedometer cable at the transmission. If it has any effect, it will be that it holds the idle speed slightly higher when rolling than when sitting still. Other than that, I'm not sure that it does much at all, at least on these trucks.
Old Aug 15, 2007 | 10:56 PM
Critter183's Avatar
Critter183
Thanks for the info.
I'll put it through the rigors and see what it says.
Old Sep 8, 2007 | 01:31 PM
Critter183's Avatar
Critter183
I got run ragged the last couple of weeks, but I eventually just replaced the TPS and MAP and it runs good now.
Thanks for the help!
Old Sep 10, 2007 | 11:50 AM
idlemonster's Avatar
idlemonster
Do you have to remove the throttle body to replace the TPS?
Old Sep 10, 2007 | 12:15 PM
Critter183's Avatar
Critter183
Yes, but it was pretty easy, and I didn't have to disconnect any water lines to get the TPS screws out.
NotEnoughTrucks2014
Mar 5, 2017 12:37 PM
joel_93f250
Jan 13, 2015 02:12 PM
delano79
Aug 30, 2011 08:36 PM
SideWinder4.9l
Jul 30, 2011 08:29 PM
Ford_Man_302
Feb 6, 2009 09:06 AM
