Maxed out Pyrometer?
Old Aug 16, 2007 | 06:05 PM
catmacanic's Avatar
catmacanic
The thermastat is what controls operating temp, the fan clutch kicks in whin water temp goes to high and needs more cooling ,more air flow throu raderator.
I had to do a test to see if a larger exhaust system was worth it. I put a 0 to 5 psi gage in down pipe before the cat. With a max hp chip in, full throttle,3000 rpm,30 psi boost, I had 4 psi back pressure in stock exhaut, ex temp about 1300 f befor turbo,
I installed a 4 in exhast system,back pressure is less than 1psi and I can't get et above 1100 f turbo get boost faster, the trade "off" is more ex noise in cab.
I's hard to believe that Ford puts shuch a minamul ex haust system on.
Cat engine spec. is less than 27 in of water of exhaust back pressure.
99 F350 7.3 auto. supperchip ,KN air filter,boost, ex temp& trans temp gages,Gale Banks ex. no cat, 4x4 drw, 355 differentals
Old Aug 16, 2007 | 06:10 PM
catmacanic's Avatar
catmacanic
Old Aug 16, 2007 | 06:19 PM
LvTitan's Avatar
LvTitan
good to hear you got such an improvement !! you can also help kill some of that "in-cab" drone from the exhaust by putting a resonated chamber in your exhaust.
sort of like a race muffler, it's a straight thru design with louvers in it, helps a lot.
you can mount it where the stock cat used to be.
Old Aug 16, 2007 | 06:38 PM
catmacanic's Avatar
catmacanic
Oh I put a 'cut off 45 deg tip on so exhaust hit the ground, also just turn the radio up a little louder.
more d
6.4L Power Stroke Diesel
May 2, 2012 05:34 PM
Joelski
23
Dec 27, 2006 07:51 AM
alchymist
Nov 15, 2006 05:17 PM
naiku
56
May 8, 2006 12:43 PM
happy hour
Modular V8 (4.6L, 5.4L)
Feb 17, 2005 04:58 PM
