Modular V10 (6.8l)
Oil flow
Old Oct 16, 2002 | 12:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Oil flow
I've never put any thought into this so I'll ask y'all.
Does the oil get filtered BEFORE or AFTER it travels through the engine?
Old Oct 16, 2002 | 03:16 PM
mechanic88115's Avatar
mechanic88115
Oil flow
It is filtered before technically. It is first filtered by the strainer at the end of the pick up tube, then pumped trough the filter and from there to all over then engine, then the oil runs down the engine back to the pan. Hope this helps you out, Mason
Old Oct 16, 2002 | 04:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
Oil flow
thanks!
Old Oct 17, 2002 | 05:33 PM
mechanic88115
Oil flow
No prob, been away from the computer for a long time and just not getting back into things. Good to be back, Mason
Old Nov 13, 2002 | 09:35 PM
Mud Doc's Avatar
Mud Doc
Oil flow
This is truly a mind-boggling question.
Seems to me the oil coming out of the engine is filtered and the oil going into the engine is filtered.
Is this a chicken/egg thing?
I knew this would happen if I used Amsoil too long.
Old Nov 14, 2002 | 05:54 AM
Monsta's Avatar
Monsta
Sit. Stay.
Oil flow
Old May 1, 2009 | 03:33 AM
Monsta's Avatar
Monsta
Sit. Stay.
W A R N I N G
Thread resurrection in progress!
Okay...someone tell me the oil flow path again. Mason's post doesn't make sense..."then the oil runs down the engine back to the pan."
Complete the following sentence please.
The oil pump pickup tube sucks the oil from the pan, it goes through the oil pump to...{fill in the blank}..finally ending up back in the pan.
Old May 1, 2009 | 06:51 AM
cbradford's Avatar
cbradford
Originally Posted by Monsta
W A R N I N G
The oil pump pickup tube sucks the oil from the pan, it goes through the oil pump to...{OIL FILTER}..finally ending up back in the pan.
Old May 1, 2009 | 07:41 AM
Johnny Langton's Avatar
Johnny Langton
The oil is drawn into the suction side of the pump via the pickup tube. It gets a slight "filtering" via the screen on the end of the pickup tube. The oil then travels through the pump where it's pressurized and pumped through the oil filter,then into the oiling passages in the block. Some vehicles are equipped with an extra oil cooler that's inline between the oil pump and the filter (integrated into the oil filter adapter housing that bolts to the side of the engine block). The oil travels through the oil passages in the block to the main and rod bearings, and also at the same time,another passage sends oil up the cylinder heads. When the oil gets there, it lubricates and camshafts and valvetrain. The pressurized oil keeps the hydraulic lash adjusters and timing chain tensioners tight for proper operation of the valvetrain. At the end of all of this lubrication process ,it will drain back to the pan via gravity to be pulled into the oil pump's pickup tube and the process starts all over again.
JL
Old May 1, 2009 | 08:15 AM
dkf's Avatar
dkf
I always thought of the filter as at mid system. Oil flow definatly starts off in the pan because thats where all the oil is at cold startup. These new vehicles have more of an oil maze than the old ones.
matowns21
19
Dec 30, 2011 09:27 AM
powerman01
Jan 23, 2009 04:08 PM
Adam0331
40
Aug 31, 2008 09:09 AM
rmcmillion2006
Dec 12, 2007 11:42 PM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
