engine hesitates
Old Aug 14, 2007 | 11:22 PM
Herman R's Avatar
Herman R
engine hesitates
I have a 89 EFI 300 inline in my 56 Mercury M100.My problem is that it has a bad hesitation when I accelerate on take off.Anybody have any ideas?
Thanks in advance
Old Aug 15, 2007 | 02:13 PM
BirdmanStyll's Avatar
BirdmanStyll
I had the same problem with my t-bird, i already had installed new plugs but not the wires and sure enough the wires were causing hesitation install good wires and ull be fine, also u might wanna lube your throttle cable could be getting stuck
Old Aug 15, 2007 | 10:01 PM
Herman R's Avatar
Herman R
Thanks
I will try that.
Old Aug 15, 2007 | 10:27 PM
89straightsix's Avatar
89straightsix
my 89 used to do that alot and just running a can of berrymans chemtool pretty much got rid of any hesitation that i had.
Old Aug 15, 2007 | 11:24 PM
Herman R's Avatar
Herman R
I've never heard of that stuff.What is it for?And where do you get it?
Old Aug 15, 2007 | 11:37 PM
89straightsix
its just a gas treatment you can get at probably any auto parts store. it comes in a red can and is about 2 bucks.
http://www.berrymanproducts.com/Default.aspx?tabid=140
Old Aug 17, 2007 | 09:44 AM
rswhitmore's Avatar
rswhitmore
Have you checked the ignition timing to make sure it is not retarded? I like to run with the timing advanced a couple of degrees ahead of factory specs for fuel economy and good throttle response. If your engine has a vacuum advance on the distributor I would check it out also. You can hook manifold vacuum directly to it to test it.
Old Aug 18, 2007 | 12:37 AM
Herman R's Avatar
Herman R
It's fuel injected.
Doesn't the computer time the engine?
I tried moving the timing but it made no difference.
Any other ideas?
Old Aug 18, 2007 | 03:15 PM
jfarcas's Avatar
jfarcas
People have had problems with stumbling, hesitation, etc due to the EGR valves on the EFI engines. You may want to investigate creating a "restrictor plate" for it to better control the amount of flow it meters. This has been known to make a vast difference in the EFI's driveability. Do a search on the forums for "EGR restrictor plate".
Good luck, keep us posted.
Old Aug 19, 2007 | 03:32 PM
Herman R's Avatar
Herman R
Thanks,I will try that and let you know how it works out.
Old Aug 19, 2007 | 03:35 PM
stractor's Avatar
stractor
Take a look at the Idle air control valve on the top of the throttle body, make sure it is working and isn't all gummed up or stuck open and the change the throttle body gasket (tech bulletin on that one). EFI timing is controled by the computer, all you can do is set the initial (base) timing--normal is 10 degrees advanced.
Old Aug 19, 2007 | 04:06 PM
Herman R's Avatar
Herman R
I did change the throttle body gasket.The old one did have a vacum leak because it was all twisted for some reason.I changed it because I replaced the stock throttle body with a larger 5 litre one.Which by the way to all you nay sayers it does definately give you better performance.Even with the hesitation I noticed the difference.
However I used the same idle control from the original throttle body.
I will check that out tomorrow and let you know how it worked out.
Thanks for the help.
Jammin1
6.7L Power Stroke Diesel
Sep 20, 2021 07:40 PM
Jay Slides
Nov 20, 2011 08:33 AM
fordmudgrappler
Oct 16, 2009 06:26 AM
Sedric
Nov 27, 2002 08:59 AM
idealtrucks
Oct 31, 2002 09:07 PM
