Wrench icon in dash
Old Aug 14, 2007 | 04:06 PM
slf06150's Avatar
slf06150
Wrench icon in dash
05' 150 Fx4 just turned 40K I was driving through a parking lot @ 15 mph when I lost my throttle. I pressed the pedal nothing happened I shifted into 1st, 2nd and drive still no throttle I shifted through he gears to make sure it was not my tranny; I coasted into a space and pressed the pedal a couple of times still nothing. Then I noticed the wrench icon lit up. I shut down, restarted and the throttle works again. Is this just a computer glitch or should I take it to the stealership? I have not had a single problem with this truck.
What do you guys think??
Old Aug 14, 2007 | 04:20 PM
cool guy's Avatar
cool guy
I suggest to get a code reader first and see what you got..
Old Aug 14, 2007 | 05:08 PM
slf06150's Avatar
slf06150
Any suggestions on a code reader. I have looked at quite a few of them. My funds are low.
Old Aug 14, 2007 | 05:11 PM
SteveVFX4's Avatar
SteveVFX4
I think you can get it read for free at Autozone or Advance Auto parts stores?
Old Aug 14, 2007 | 05:38 PM
Moore558's Avatar
Moore558
The wrench light is the fault light for the Electronic Throttle Body control. When a fault is detected in the system, the wrench light comes on and you are either on forced idle or reduced power. There are many things in the ETB system that can trigger this so have autozone or someone scan the codes for you and see what 2 or more codes you get. I say 2 or more because typically when a ETB code is set, one is an informational code and the other one is the actual code. Good luck.
Old Aug 14, 2007 | 07:32 PM
Firemut30's Avatar
Firemut30
If it is under warrenty take it in. I am sure they will need it for a day, and thats with an appointment, but make them responsible for it.
Old Aug 15, 2007 | 07:35 AM
slf06150's Avatar
slf06150
Since I got the wrench icon I have driven over 70 miles, to from work stop and go traffic and no problems since. I am going out of town tomorrow with the truck. I plan on going to AutoZone to have the codes scanned. I'll post back when I find out what the codes are. Thanks to all for the suggestions.
americanbuckeye
Aug 19, 2015 06:38 AM
JESimmons
Jun 28, 2013 02:57 PM
Midnight Express
Sep 7, 2012 10:52 PM
notawordok
Aug 5, 2010 01:53 PM
TheMech
Mar 16, 2008 06:03 PM
