help with some wiring issues please
Old Aug 14, 2007 | 10:22 AM
ryans69's Avatar
ryans69
hi there i have a 1969 ford f-100 300 6. I have just recently taken apart the whole front section of my truck sanded primed and my now putting it all back together. On the front radiator support piece, You have your horn and below that i believe the voltage regulator and the is a almost batter shaped piece below that. Well there is only one wiring running to it and its from the voltage reg. But the wire snaps apart and now i am having the problem of getting it back together snug. I was just wondering what that piece does if i cant figure out a way to get it back together correctly im thinking about splicing it but i was just curious as to what it is and does. Thanks all the help is appericiated heading out camping today and i want to take my truck! Ill post some pictures of my progress as soon as i get back thanks for all the help people!
ryan
Old Aug 14, 2007 | 01:03 PM
blue68f100's Avatar
blue68f100
On my 68 there is a single wire from the voltage regulator to ground, if thats what your talking about. 4 wires to reg, 1 to horn. I do not have any wiring in my truck right now. Every thing is stripped out for paint, inside and out. The white wire from the regulator "T" temninal goes to engine, switched. Not sure where it switched at, mat terminate on soleniod.
Old Aug 14, 2007 | 02:58 PM
Freightrain's Avatar
Freightrain
I thing that is some kind of condensor, like you find in your points distributor. Can't really say what it does for sure, and where to get one? I think if you switch over to a new "electronic" regulator it wouldn't be required. Can't say for sure.
Old Aug 14, 2007 | 03:46 PM
blue68f100's Avatar
blue68f100
If it a condensor it's to filter radio noise. There should be a number on it in mf. If the connector is loose use a pair of pliers and tighten it up. Some condensors had pigtails on them, if it came apart their, just remove and throw it way. Parts houses use to carry them. Would not hurt to check.
Mine originally did not have a radio, so it was not equipped. I do not have any radio noise with out it.
Old Aug 16, 2007 | 07:39 PM
ryans69's Avatar
ryans69
well thanks guys i had a blast took it out camping and got it barried in dirt up to the axle. ill try and put up some pictures but im not sure how
67F250RET
Sep 4, 2024 12:10 PM
Ryan313
May 2, 2015 02:37 PM
maximumd93
Mar 11, 2013 09:52 AM
fishmanndotcom
235
Nov 29, 2011 06:27 AM
Blacksnake
Aug 27, 2009 09:08 PM
