Cps ?
Old Aug 14, 2007 | 06:55 AM
tndiesel's Avatar
tndiesel
Cps ?
I have my extra CPS in the glove box. What size socket fits it to change it if it goes out on the road somewhere? I just want to have what I need and a flashlight because I know it will happen at night in a hurricane like rain storm.
Thanks!
Old Aug 14, 2007 | 07:02 AM
MLCinNCTX's Avatar
MLCinNCTX
A 10mm socket and sometimes a screwdriver is needed to pry it a little.
It is best to check that you have everything you will need and really get under the truck on a dry day in the light to check location and tool fit. I have heard guys say you need a medium deep socket, but I just used a 1/4 deep well.
Old Aug 14, 2007 | 10:48 AM
joe_13894's Avatar
joe_13894
I just did the change last night. I used a 10mm 6 point deep socket. If you are using a 3/8" drive ratchet, you probably need an extension because it's fairly close to the dynamic balancer and pulley. I used a 1/4" drive ratchet and the head of the ratchet was small enough to get onto the bolt. With an extension you'll be fighting the fan instead though.
Old Aug 14, 2007 | 11:26 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Changed mine with a 10mm combination wrench, and a screw driver for prying. Sometimes those 10mm bolts get in there real tight, thanks to the vibration of the engine. That's common with diesel engines, bolts do have a tendency to tighten up over a period of time. Sprayed mine with PB Blaster the night before I changed it. Of course if you are on the side of the road, you won't have time for that.
Old Aug 14, 2007 | 12:07 PM
tjbeggs's Avatar
tjbeggs
If I were you I would practice removing it when its nice and sunny out. It will be two fold. you will make sure the bolt will come out and you will know exactly what needs to be done when its dark and raining out when you need to change it on the side of the road. I also recommend putting never sieze on the bolt. also be warned that the o-ring might need to be changed if you remove the old sensor to be reinstalled.
Old Aug 14, 2007 | 12:42 PM
Mark62's Avatar
Mark62
I always thought vibration tended to losen bolts...this is news to me about diesels.
Old Aug 14, 2007 | 01:42 PM
CampSpringsJohn
Vibration goes both ways with bolts. Caterpillar engines are horrible for that, especially the drain plugs and oil filters. While they will certainly loosen up sometimes, they can also tighten up too. I use to service a few trucks that belonged to an escavating company, they had C-12 cats in them. I would put the drain plug back in with a half drive ratchet, and at the next oil change, I would sometimes have to get my 3/4" impact to get the plug out. I would install oil filters hand tight and distroy a filter wrench getting them off at the next change. I found out the best filter wrench for removal of a stuborn filter, assuming you have room to use it, is a real big pair of channel lock plyers. In extreme cases, a hammer and chisel may be necessary. I hate that method.
Neal 97 250's Avatar
Neal 97 250
I guess it can work both ways. BTW where is cookietown? LOL
Old Aug 14, 2007 | 03:26 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Thanks!
Somebody told me "put the new one righ now (not at night in the middle of a storm), and the used one, put it in the glove box".
I think it has some sense, dont you?
Old Aug 14, 2007 | 04:42 PM
Mark62's Avatar
Mark62
West of Knoxville...Cookeville, TN.
Just how far west of K-town are you?
I will be in K-town on the 28th...
Old Aug 14, 2007 | 10:01 PM
origcharger's Avatar
origcharger
Kind of like them tassles at the "shaker" bar eh?
Old Aug 15, 2007 | 05:22 PM
Neal 97 250
Technically Harriman but get off of the Kingston exit. In sugergrove valley. Not far from you.
Old Aug 15, 2007 | 05:24 PM
Neal 97 250
Yeah, up/down and round and round...inside out and round and round. Kinda sounds like a song. Maybe I do have talent.
