Sponsored by: Auxito
differential help
Old Aug 14, 2007 | 02:40 AM
seth1's Avatar
seth1
differential help
hey, im kinda new to differentials and have a couple questions about putting limited slip in my 00 f150 5.4. im hoping to do this cheaply. i was thinkin about getting some old stock ones from a junkyard and just replace the clutch packs or however fords stock ones are. and could i use my old gears too? is it hard to change out the front one? is it the same as the back?thanks, seth
Old Aug 14, 2007 | 10:02 PM
fatforty's Avatar
fatforty
Being new to setting up differentials is not a good thing, if it was mine to do I would go to the junkyard and find a complete rear that has the same ratio and the limited slip already in it. Setting up a rear isn't much fun when you can take out the center section, and these don't come out anymore. Everything has to be set in the truck and there are special gauges to do this.
Old Aug 15, 2007 | 11:05 AM
seth1's Avatar
seth1
thanks for the input. do the stock limited slip difs wear out easy or should they last quite awhile? and what about the front??
Old Aug 15, 2007 | 04:23 PM
duggyb's Avatar
duggyb
yeah i would just pick up a limited slip off ebay($150)...and take your axle out of your truck...(takes 20 minutes to drop an axle)...load it up and take it to the dealer....i took my axle...used limited slip and and a new 3:55 gear set to ford dealer...charged me $230 to get it all put in and the bluuing pattern set and everything....smooth as a whistle now.
THNX
Duggy
