Door Panels.....again
Old Aug 14, 2007 | 12:23 AM
Pud12343's Avatar
Pud12343
ok lol...are there any other kind of door panels available other than the origional ones?
Old Aug 14, 2007 | 01:52 AM
bucks77ford's Avatar
bucks77ford
Do you mean other than original style? No different style is made. You would have to customize your own.
Old Aug 14, 2007 | 09:29 AM
beartracks's Avatar
beartracks
I used the Coverlay units. Not quite exactly original but close enough in my case.
Old Aug 19, 2007 | 10:13 PM
Frontier_Bill's Avatar
Frontier_Bill
While on this topic, where would be a good place to get my hands on some 'new' door panels for a '77 f-150 without paying an arm and a leg?
Old Aug 19, 2007 | 11:21 PM
Broken40's Avatar
Broken40
J -J -J -J -junk yard my friend, or you could by them brand new from lmc truck, but as you said you don't wanna spend an arm and a leg, so i would go to a junk yard
Old Aug 20, 2007 | 01:26 AM
Bart8109's Avatar
Bart8109
Like Broken said, junk yard. I fiberglassed mine on the backside and bondo on the face side and repainted them. They turned out well. Much better than paying an arm and leg from LMC.
Old Aug 20, 2007 | 04:45 AM
Frontier_Bill
Hmm. Well, looks like a road-trip is in order then. I refuse to do business with the local junk-yard guy since he has shafted me and screwed with me way too many times. The biggest problem is that the previous owner of my truck (older, bad mechanic/electrician, brother) decided that he needed to remove the door panels to mount 6"x9" speakers. Improperly. He used a clip hole as a bolt hole for the crappy speaker. Now there is no anchor points left with enough plastic to mount the clips to the door panel.
What would be the best way to 'rebuild' the clip base? Fiberglass? Epoxy? Bondo?
Old Aug 20, 2007 | 10:45 PM
Broken40's Avatar
Broken40
i would bust out fiberglass, and i say that only bec. you can get kits that you can cut out just the right size so you don't have to get a bunch o' bondo on...not only that bondo cracks with heat, and fiberglass you can heat it to almost any temp and you have no problems...i know that bec. i cut a whole in my heater core holder thingy so i wouldn't have to take the whole damn thing out and fiberglassed it back together and have not had a problem since...so yeah fiberglass is a good idea.
Old Aug 21, 2007 | 04:27 AM
Frontier_Bill
I may have to get some fiberglass then. However, I found another salvage yard tucked away in town that has 4 trucks with parts I can use. I plan to get some of the trim from the Ranger XLT trucks, cab markers and mirrors from a 76 F-250, and hopefully the black carpeted door panels from a 77 F-150 Ranger XLT. I hope I can get all this stuff. The trim pieces will cover a lot of my exterior blemishes due to a previous bad bondo job and rock chips in the paint.
Old Aug 21, 2007 | 12:39 PM
dirtjumper01's Avatar
dirtjumper01
you call $150 an arm and a leg? I bought mine from LMC, they look kinda cheap, but there made by a reputable company
Old Aug 21, 2007 | 12:57 PM
NOCO77's Avatar
NOCO77
If you don't mind dyeing them to match each other, dennis carpenter has them for 100/pr and they're made from original ford tooling/dies. They are mismatched or possibly multi-colored because of color changeovers during production - cosmetic only, functionally good.
Old Aug 21, 2007 | 01:08 PM
BigGrizz76's Avatar
BigGrizz76
I found mine on Ebay for $60 for the pair and they are brand new in the package!
Just keeps your eyes open and your head on a swivel.
Old Aug 21, 2007 | 02:48 PM
NOCO77's Avatar
NOCO77
Wow, $60 is great! I found mine in the boneyard for $75/pr - original ford xlt's, but I still had to disassemble and dye them.
BigGrizz, I noticed your a fellow Coloradoan - where 'ya at?
Old Aug 21, 2007 | 03:19 PM
BigGrizz76's Avatar
BigGrizz76
Greeley. What about you?
Don't mean to hijack the thread.
If you are going to dye the panels, you could mix and match with whatever you come across...I got a green one you can have if you pay the shipping, pretty good shape. IM if interested
Old Aug 21, 2007 | 10:19 PM
Broken40's Avatar
Broken40
Well beings how not everyone has $160 to spend on "door panels" i would assume the junk yard way would be "cheap" bec. then they only cost $20-$30 at the most....you have to keep in mind my friend that not everyone is made out of money....(no offense please don't take that the wrong way)but just like every consumer out there, it's nice to save a buck or two. just keep that in mind.
