2.9-3.0 interchangeability
Old Aug 13, 2007 | 10:45 PM
hush210's Avatar
hush210
Does anyone know if the transmission bolt pattern is the same on the 2.9 and the 3.0? the truck is a 86 ranger with a 5-speed.
Old Aug 14, 2007 | 06:49 AM
Rockledge's Avatar
Rockledge
The bolt patterns are not the same.
Old Aug 14, 2007 | 04:21 PM
hush210's Avatar
hush210
So Im gonna need a new tranny if I wanna use this motor?
Old Aug 20, 2007 | 12:34 AM
mebe2k's Avatar
mebe2k
if it is a 2wd you could use a tranny out of a 3.0L manual Aerostar..
Old Aug 20, 2007 | 05:31 AM
Pablo-UA's Avatar
Pablo-UA
Ore bellhousing only. BTW. I have 3.0 Aero converted to MT5. People say that 3.0 is better then 2.9 and I dont know why?
Old Aug 20, 2007 | 09:31 AM
BSmitty's Avatar
BSmitty
Although the trans in your '86 has a removable bellhousing, the 3.0l was never mated to any other trans aside from the Mazda, which has a 1-piece body, no seperate bellhousing. So the short answer is yes, you'll need a new trans to use a 3.0l, along with a wiring harness, since the engine management system is set up differently between the 2 engines. Stick with the 2.9l IMO, just as powerful, and durable if properly cared for, and probably cheaper used.
robert_l_ross
Jun 20, 2024 10:16 AM
xTraveler
May 26, 2024 10:21 PM
shovelhead1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
51
Feb 21, 2014 10:28 AM
dldagneau
Aerostar
Mar 6, 2007 05:14 AM
gomsu
13
Aug 30, 2004 09:38 PM
