Modular V10 (6.8l)
high idle
Old Dec 10, 2002 | 04:18 AM
heshmastr's Avatar
heshmastr
high idle
i have a 2000 x with a v-10 but my idle while warm is at 900 rpm. is this normal? and is there anything i can do to back the idle down? thanks for your input.
Old Dec 10, 2002 | 07:06 AM
Monsta's Avatar
Monsta
Sit. Stay.
high idle
Your idle is a bit high. I idle around 600-700.
High idle concerns can manifest themselves from a few different areas.
1. Vacuum leaks. Check all the intake connections from the MAF up to the throttle body. Check for cracks or looseness.
2. Malfunctioning PVC. Remove and clean. Flip it up and down and make sure you hear the clicking noise.
3. Disconnect the connector to the IAC valve. If the RPMs DO NOT drop then the IAC needs to be replaced/cleaned.
4. Inspect all the vacuum hoses for leaks, cracks, punctures.
900 when warm isn't too bad but it does seem out of spec.
Old Dec 11, 2002 | 02:12 AM
Gary E K's Avatar
Gary E K
high idle
[updated:LAST EDITED ON 11-Dec-02 AT 03:17 AM (EST)]>i have a 2000 x with a v-10 but my idle while warm is at 900
This is just about what Monsta said but baybe a little dif.
l Listen for vacuum leaks.
l Inspect entire air intake system from the mass air flow (MAF) sensor to the intake manifold for leaks such as:
-- cracked or punctured inlet air tube.
-- loose connections on the inlet air tube at the air cleaner housing or throttle body.
-- idle air control (IAC) valve assembly or gasket seal.
-- EGR valve gasket seal leak to intake manifold.
-- Intake manifold assembly or gasket seal.
-- EGR valve diaphragm or control solenoid.
-- vacuum supply connectors and hose.
l Are any leaks detected?
Yes
KEY OFF. REPAIR any leaks.
No
REPLACE IAC valve if idle speed does not drop when disconnecting harness connector otherwise, KEY OFF. GO to «HU10».
If you need anymore assistance
me at "garyekuy(No Email Addresses In Posts!)
Old Dec 25, 2002 | 12:43 AM
Barney67's Avatar
Barney67
high idle
Talked to a Ford Tech, 600-800 RPM is the spec. My X is idling between 700-900. :-X12
Old Dec 25, 2002 | 04:46 AM
Gary E K's Avatar
Gary E K
high idle
Not enough to worry about, I would think.
:-X23
Old Dec 27, 2002 | 08:47 AM
jaxf250's Avatar
jaxf250
high idle
Curt's05
Nov 24, 2013 08:03 PM
skoalboy87
Jan 24, 2008 01:12 AM
i1dery
Jan 13, 2008 04:25 PM
Jag Red 54
Aug 17, 2004 03:56 PM
