460 vs. V-10
cause the 93 psd had nasty exhuast and had to use ether
to start it sometmes in the cold.but the 00 psd (both 350 crew)
has clean exhuast and is hassle free affter 106 000 km.
I guess its just whatever turns your crank! cause I would
rather drive gas powered stuff around but deisel is
good for work.V-10s seem real smooth etc but its a new
engine that is in the crude start out.sticking valve,
lifters, piston slap,blown gaskets(head)etc. occuring
before 50 000miles sometimes,460cid can make more than
one needle move at quite a pace under heavy reving.
Fe power
as for any changes between '94 and presant i don't believe that there were many if any at all.
If you had to use ether on your truck then your glow plugs needed to be looked into.
. If you can aford the 99 and up go for the 10, if not go for the 460, either way you won't be disapointed. Hope this helps, Mason>indirect injection, the Direct Injection Powerstroke came in
>'94. All Powerstrokes are turbocharged, but the early
>models were not intercooled. I don't think they became
>intercooled until '98 or '99. The first powerstrokes
>produced 425 lb-ft of torque. Then when the intercooler was
>added, it was increased to 500 lb-ft. Now it has been eased
>up to 525 lb-ft. (Units built after January 14, 2002).
I believe the first diesels were the 6.9's, not 7.3.
. If I have missed something please feel free to add it in a post below, Hope this helps, Mason>diesel was 1983 with the 6.9L. The 6.9 was offered through
>the body change in 1987,in 1988 the 7.3L indirect injection
>was offered and was the only choice till 1993 when they
>offered a turbo version of that engine, there was also a 7.3
>that was offered in 93-94 that I am not sure about it was
>something different I believe that ford made it but not
>sure, it was a turbo charged engine, that had some sort of
>computer control system on it, but I have not seen one in
>person. In 1994.5 the direct injected 7.3L was offered,
>this is the powerstroke, but was not badged as such till the
>1995 model year this engine was offered in it's 210hp 425
>torque version till 1997 when the 5 speeds gota 225hp
>version. In real late 1997 or early 1998(I can't remember
>for sure) as a 99 model the addition of a intercooler caused
>the hp to go up to 235 hp for both auto and the new 6 speed
>standard. In the 2001 model year the hp was upped (By
>programing and fuel delivery system mods I believe) to 250hp
>for the auto, and 275hp for the 6speed, and that is were we
>set now. I have not seen anything yet that was positive on
>the g2 psd, but it sounds interesting, and the international
>version (the "VT365") should be at the international house's
>right now. Ok this is the off topic overrun on the history
>of ford diesels
. If I have missed something please >feel free to add it in a post below, Hope this helps,
>Mason
Great info!!!
The v-10 has no such problems. It will maximize your gear selection with a broad powerband. You can shortshift at 1600 rpm or wind it to 5k.
I think the 460 is a good motorhome motor, but for everything else, I'm glad I've got the "10" now.
As far as mileage, the "10" gets 25% better mileage than both the 460's I had. Just my HO
82' Flareside: zoom zoom doesn't even begin to describe it
2/4 Drop
Soon to have 325hp 351 Clevo
(maybe more,in a 3600lb truck)
Backed by a C6 with a 2000 rpm stall and a 3.50 9 incher
American Racing AR-23 (series 23) wheels
Upgraded interior
Soon to have a kick @$$ stereo
There's not a replacement, but there is a supplement and it's called technology. That explains why you can get more HP and torque from the current V10 than the 460 that it replaced. Sure, there is more room for power increases in a 460 engine, but most people on the road drive their vehicle in the stock configuration anyway.
