272 timing
Old Aug 12, 2007 | 09:21 PM
Paul Casey's Avatar
Paul Casey
272 timing
Newbie here. My Dad has a '55 Ford with the 272 Y block. He has timing issues. Anyone know where to set the marks on the cam and crank gears for base timing. Most motors I've done have the cam mark at 6:00 and the crank mark at 12:00 when cyl. # 1 is at TDC compression stroke. The marks on his are nowhere near this. The motor runs (although like crap) so I don't think we are too far off. If I set the marks like the shop manual shows at both at 3:00, the rotor points about 180 degrees off, and the #1 piston is not at TDC. Any help is appreciated. Thanks
Old Aug 21, 2007 | 11:56 PM
Fomoko1's Avatar
Fomoko1
A big welcome, glad to have you join in!
It`s a little late for a reply but for your answer drop into the Y-Block V8 (239, 272, 292, 312, 317, 341, 368) forum: https://www.ford-trucks.com/forums/forum56/
Old Aug 22, 2007 | 12:48 AM
HT32BSX115's Avatar
HT32BSX115
You may have something else going on there. If I'm not mistaken, ALL Y-blocks have the cam and crank marks at about 3:00
http://www.ford-y-block.com/assemblyerrors.htm
Cheers,
Rick
Old Aug 22, 2007 | 07:37 PM
Paul Casey's Avatar
Paul Casey
Long story short: When his engine was rebuilt, the wrong harmonic balancer was installed. He had the correct one at the house, which when installed, worked. Yes the marks at 3:00 seems only to be a rederence for cam and crank timing, although not related to #1 at TDC. Anyway, problem solved, and thanks to all.
Old Aug 23, 2007 | 07:53 AM
312's Avatar
312
there are 12 pins between timing marks.#1 is on pass,side.
Redseven
Mar 4, 2024 07:21 AM
HappySailor
Modular V8 (4.6L, 5.4L)
Dec 13, 2014 03:35 PM
79smurf
May 15, 2014 03:38 PM
fixnair
May 9, 2012 03:34 PM
msumrell
1983 - 2012 Ranger & B-Series
Feb 7, 2004 10:35 AM
