AOD T.V Pressure
Old Aug 11, 2007 | 09:24 PM
302 F-150's Avatar
302 F-150
AOD T.V Pressure
I converted the 302 in my 89 f150 from efi to carb and I am trying to adjust the kickdown cable with a pressure gauge. I am using a lokar KD-2AODHT kickdown cable and when I have the tranny in any gear at idle the pressure is over 100 PSI. I haved tried pulling on the cable and cannot get the pressure below 100 PSI. Any Suggestions?
Old Aug 13, 2007 | 12:29 PM
l-m tech's Avatar
l-m tech
when you hooked up the gauge you did install the pressure gauge in the t.v. pressure port.should be the middle one on the rr of the trans
Mutilator712
Oct 12, 2016 06:08 PM
Building_Fords
Sep 5, 2016 09:24 PM
schoo
Apr 2, 2016 09:59 AM
xeroshi
Jun 19, 2015 01:18 PM
F-250 restorer
Jan 12, 2013 01:47 PM
