Insulation Question
Old Aug 13, 2007 | 05:28 PM
Okiedokie's Avatar
Okiedokie
John, in Oklahoma in 100 degree heat Lizard Skin by itself is not the ticket for heat control. That is also true for the B-Quiet. However, put em together and you've got something. The "mylar bubble wrap" stuff is also not very helpfull at that temp. Maybe you and Vern could live with it where you are, but not here. I do not understand how the foil works to the inside, but my tests showed it to work best that way, unless it was in direct contact with the rays of the sun. Joe
Old Aug 14, 2007 | 07:16 AM
GreatNorthWoods's Avatar
GreatNorthWoods
The brackets (guess they are called brackets???) that hold the stock lower door seals in place were rusted away in my truck so I glued a piece of deck lid rubber from my donor car in their place. It seems to be working okay. There is not much you can do about that open hole in the front sides. I painted that area with POR-15 so I hope the rust doesn't come back soon. I gave some thought to using foam too but decided against it...
Old Aug 14, 2007 | 10:22 PM
51ford fan's Avatar
51ford fan
Thanks Vern, sorry I didn't explain myself better in the last post. I was at work on my break with a half dozen things on my mind.
Old Oct 1, 2007 | 04:23 PM
Okiedokie's Avatar
Okiedokie
An update on Lizard Skin or Cool Car Ceramics ceramic spray on insulation. As I noted previously I used these on my 40 coupe. This weekend a friend came by with an expensive tester that measures coating thickness in mils. His brother is in the paint shop supply business and had it as a sample. He had used it find out when he got to 40 mils applied to his truck. He rolled on three coats to get to 40 mil. We used it to test the thickness on my 40. On the inside that was sprayed by a local body shop that does it regularly it varies from 10 to 20 mils, on the underside that I sprayed it is about the same. The shop used 2, 2 gallon buckets to do the inside, top to bottom, side to side. I used about 3/4's of a 2 gallon bucket underneath. Didn't get close to their recommended 40 mils. At least the floor has a coat on each side. I am contemplating using what I have left to put another coat on the underside of the roof. Although it would be applied to the B-Quiet I have installed already. Not sure what I will do there. Anyway, FYI 40 mils is much thicker than I would have thought. I don't know how you would know for sure without a gauge. Joe
Old Oct 1, 2007 | 04:27 PM
Randy Jack's Avatar
Randy Jack
Thanks for the update, Joe. That info is helpful.
Still thinking about the possibilities....
Old Oct 2, 2007 | 12:51 PM
brucewolff's Avatar
brucewolff
The foil on the insulation is vapor barrier. In building construction it should go on the warm in winter side of the insulation. It kind of depends on which side of the mason/dixon line you are on.
However, if my memory serves me right the Big 3 automakers put a poly vapor barrier on the inside surface of the doors. This keeps the water vapor from getting inside the door.
HRTKD
All Things Towing
31
May 27, 2016 03:26 PM
351Cleveland C4
29
May 5, 2014 10:48 PM
Hotwheelbill
Mar 12, 2014 07:09 PM
Frost_26
1978 - 1996 Big Bronco
May 1, 2010 09:17 AM
Aftrmidnite
Garage & Workshop
38
Sep 6, 2004 10:48 AM
