Sponsored by: Auxito
No gear code on sticker???
Old Aug 11, 2007 | 12:26 PM
JUGGALO_6's Avatar
JUGGALO_6
I have a 2000 f150 4.2V6 2wd manual trans. I installed larger tires (BFG AT/KO 265/70/17) and lost horsepower as expected. Now I'd like to change the gear ratio but I don't know what it has now. Where the code is supposed to be is blank. Could anyone tell me what I might have and any suggestions on what I should put? I was thinking 3.55's. Am I wrong?
Old Aug 11, 2007 | 01:16 PM
steve(ill)'s Avatar
steve(ill)
look for a steel tag bolted to the rear axle pumpkin- see the code there.
Old Aug 11, 2007 | 01:33 PM
JUGGALO_6's Avatar
JUGGALO_6
I'll look for that. Thanks!!! Would you consider putting 3.55's in it to increase acceleration and torque?
Old Aug 11, 2007 | 05:38 PM
steve(ill)'s Avatar
steve(ill)
lets say you tires were 29 inches in diameter and you increased that to 32 inches. that would be 3 inches more or 10%. to keep the same ratio, if you had a 3.20 axle you would want 10% or .32 more so 3.52 would be 10% and the 3.55 ratio would be a good choice.... measure your tires and get your old ratio. you might go a little extra since the new tires are heavier, and the lower ratio will also give you a little more grunt at the low end takeoff.
Old Aug 11, 2007 | 06:38 PM
JUGGALO_6's Avatar
JUGGALO_6
Thanks alot Steve! Really good info I could use.
Old Aug 15, 2007 | 10:28 AM
JUGGALO_6's Avatar
JUGGALO_6
OK. I looked at the pumpkin and it said 3.08??? Is this job of changing the diff ratio hard? I kinda know my way around a truck but I'm definatly NOT ASE certified. I also want to put a body lift on,I was thinking about 3". Can anyone recommend a product?
miashley150
35
Feb 12, 2013 10:56 PM
Tom Newman
Sep 6, 2011 06:09 PM
six6six
Jul 30, 2011 10:39 PM
ramboss429
1997 - 2003 F150
Mar 27, 2006 02:50 PM
torino man
May 8, 2001 10:12 PM
