PS pump end play
Old Aug 10, 2007 | 10:19 PM
fatboy*61's Avatar
fatboy*61
PS pump end play
'97 F350 7.3 with a late build date. I have about 3/32" end play in the power steering pump. Is this considered normal?
Old Aug 10, 2007 | 10:28 PM
fatboy*61's Avatar
fatboy*61
I also found the fan to be loose. Seems to be the fan clutch, not the water pump. Anyone ever hear of them coming apart while driving?
Old Aug 10, 2007 | 10:43 PM
61 uni's Avatar
61 uni
Mine fell off last Saterday. I put it back together with blue locktite.
Old Aug 11, 2007 | 06:09 AM
Cuda_jim's Avatar
Cuda_jim
That may be a bit much but new PS pumps have a little end play....about 1/32 inch IIRC, I never measured it though.
Old Aug 11, 2007 | 06:15 AM
Cuda_jim's Avatar
Cuda_jim
Do you mean the small shaft has slop going to the clutch? If so your clutch is getting worn and yes they are known to come apart. If that happens you'll be buying a new radiator, fan shroud and anything else it decides to destroy. Our local EMT's always replace the fan clutch whenever the radiator is replaced.
Island Time
Oct 30, 2014 10:23 AM
lesolred
Aug 9, 2008 10:32 AM
rivershark33
Sep 19, 2007 12:25 PM
RA81222
1978 - 1996 Big Bronco
Apr 20, 2006 09:54 PM
recips
2004 - 2008 F150
Nov 18, 2003 09:15 PM
