P/S Pump End Play
Old Oct 27, 2014 | 02:29 PM
Island Time's Avatar
Island Time
P/S Pump End Play
'90 F150 351W E4OD
How much end play is normal or acceptable in the power steering pump? On my pump there is enough that pushed all the way against the pump body the pulley lightly scuffs the bolts on the pump body. My instinct is that's too much and the pump should be replaced. But, being new to Fords I thought I'd check with the brain trust before spending money.
Old Oct 27, 2014 | 07:06 PM
SAF's Avatar
SAF
maybe 3/32" or less Id guess
Old Oct 28, 2014 | 07:19 PM
Island Time
So a certain amount of end play is normal?
Old Oct 28, 2014 | 11:08 PM
fordboy97's Avatar
fordboy97
My pump has a bit of play in it as well. Not sure if this is normal but the pump works fine.
Tanner
Old Oct 28, 2014 | 11:33 PM
joey2fords's Avatar
joey2fords
a rotating part making contact with a fastener isn't likely to end well . sounds like time to replace it.
Old Oct 29, 2014 | 10:34 AM
Island Time
That was my thinking as well. But, as I said above, I'm new to Fords and didn't know if this was normal or not. I think I'll go ahead and change it, since with the front clip and core support off the truck it should be a lot easier.
Old Oct 29, 2014 | 05:16 PM
SAF's Avatar
SAF
yes a slight bit is normal in my experience. Based on your description it would seem yours needs to be replaced...
Old Oct 30, 2014 | 10:23 AM
Island Time
Ok, new pump it is. Thanks all.
Opossum
Jun 26, 2010 12:41 PM
Welk49
Feb 27, 2010 01:17 PM
Miller
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 1, 2008 06:44 AM
