Need help
Old Aug 10, 2007 | 02:52 PM
meanv10's Avatar
meanv10
Need help
I have a 03 F350 v10 and got a used Kenne bell superchager for it off Ebay, It came with a FMU and a boost a pump, So i ditched the FMU and got 36 pound injectors and a new chip from kenne bell, in order for the injectors to work i had to cut off the old injector plugs and solder the new harnesses in, I also put on NGK plugs that are a heat range cooler and gaped them to 35 thousandths, But I got a autometer wideband A/F gauge, and when im at 3000 rpm the gauge reads 11 to 12 and at 4500 rpm it reads 10.2 also when i get off the gas it reads 16 for a few second and then goes back to 14.7. I know that this cant be right does anyone know what i should do any advise would be appreciated.
Old Aug 10, 2007 | 04:11 PM
phil6608's Avatar
phil6608
So whats the AFR gauge reading at WOT?
Old Aug 10, 2007 | 09:52 PM
meanv10's Avatar
meanv10
10.2:1 and stays there till i let off
Old Aug 10, 2007 | 10:41 PM
FTE Herman's Avatar
FTE Herman
So, any particular issue you are experiencing?
Old Aug 11, 2007 | 06:01 AM
phil6608's Avatar
phil6608
10.2 is a little rich at WOT but that's ok. Better safe then sorry.
Is your gauge a good one or a cheapo? If it's a cheapo it could be the gauge.They tend to jump all over the place.
Have you ever had it on a dyno. Were they hook right in to your 02 port to get the AFR?
As you can see by this dyno graph. It starts out way lean and then holds a good 11.5 across the board.
Old Aug 11, 2007 | 02:09 PM
meanv10's Avatar
meanv10
The wideband o2 is the best I could buy from autometer i paid 320 for it doesn’t jump around and is accurate. it has been on the dyno when i still had the fmu and it wasn’t doing consistent pulls and would jump form rich to lean that’s why i went with bigger injectors, and after I did the injectors i got the A/F gauge, but i know that it is very accurate. But when i told the guy who did the dyno pull for me that it currently runs 10.2 at WOT he said it wasn’t good and be thought that the boost was blowing out the spark, every thing feels fine to me and its only 6psi kit, Which leads me to another question now, After seeing how much boost you guys are running do you guys think I could get a 9psi without damaging anything to get some more power and lean it out a little?
Old Aug 12, 2007 | 05:57 AM
phil6608's Avatar
phil6608
Do not go from 6 to 9 PSI without a new tune! You could blow it up.
With a proper tune! (Yes) you can run 9 psi on the stock block.
Sorry but the way I'm reading your post it sounds like you put bigger injectors in without a new tune. Is this correct?
Old Aug 12, 2007 | 08:13 AM
meanv10's Avatar
meanv10
No the when i ordered the new injectors from keene bell i also got a new chip from them.
Old Aug 13, 2007 | 06:31 PM
meanv10's Avatar
meanv10
So after what i have told you guys so far do you think i could run a water/methonal kit? And if you buy a kit do you have to get a new tune in your truck? Also are there any disadvanteges to water/methonal? dose the water cause rust in the supercharger?
thanks for the help guys.
Old Aug 14, 2007 | 04:27 PM
FTE Herman's Avatar
FTE Herman
I gotta run right now, but will get back to you with my input.
Old Aug 14, 2007 | 11:16 PM
phil6608's Avatar
phil6608
Yes you can run a W/M kit without tuning. But you will get much more benefit & power from it if you tune for it.
The only disadvantage to it that I know of is keeping the bottle full,,,lol.
I had a Snow Performance kit on my truck for a long time.
If your running the non inter-cooled KB it will help a lot in keeping things cool!
Old Aug 15, 2007 | 03:25 PM
AIS's Avatar
AIS
It's funny because we hear the same complaint about our competitor's kit all the time... not enough water/alcohol capacity.
Our trunk mount system comes with a 1.5 gallon tank. On most vehicles this will last about a month. If you're doing some serious towing you may have to fill it up a little more frequently but you will undoubtedly fill your fuel tank up more than you will fill your water/alcohol tank up!!
Now, some guys on here do some serious towing everyday of the week. For those applications we can set up a 6 gallon tank. Either way, we have the set up to prevent having to fill your water/alcohol tank up every couple of days.
WATER WILL NOT CAUSE RUST IN THE SUPERCHARGER The water (which is a very, very, very fine mist) just won't last inside the supercharger because of the air velocity traveling through it and the enormous amount of heat generated. Also, your supercharger should be constructed entirely of aluminum which doesn't really rust.
- Nathan
Old Aug 15, 2007 | 03:44 PM
phil6608's Avatar
phil6608
hahahahaha Nathan, Go get um.
Old Aug 15, 2007 | 04:45 PM
meanv10's Avatar
meanv10
Thanks for the help, Ill most likly get a kit in the future and see what it can do, I called kenne bell and they told me to get a water metonal kit and a smaller 8lb pully with a new tune. That was after i asked them if they sold a water to air intercooler for my v1o.
rock2610d
Modular V10 (6.8l)
40
Mar 13, 2016 04:27 PM
rlauer
Ford Truck Parts for Sale
Oct 21, 2015 08:01 AM
V10RP
13
Nov 2, 2012 08:55 PM
monkei
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Sep 7, 2009 12:00 AM
V10RP
Modular V10 (6.8l)
90
Sep 19, 2008 11:49 AM
