Sponsored by: Auxito
can you help me :{
Old Aug 10, 2007 | 11:11 AM
zjxtreme's Avatar
zjxtreme
can you help me :{
1997 f150 4.6 it misfires on #1 and #8. it shakes like crazy at any speed and idle. I have new plugs,wires,coil packs,and new injectors in those two. I have good compression,spark,and fuel. What could it be? no engine light on but pulled codes p0301,p0308,and p1151
Old Aug 10, 2007 | 01:33 PM
Skweeker's Avatar
Skweeker
P0301 = Misfire cylinder #1
P0308 = Misfire cylinder #8
P01151 = Bank 2 Sensor 1 slow switching / no switching
Bank 2 is the driver side cylinder head and Sensor 1 is the O2 sensor closest to the exhaust manifold. Bank 2 contains cylinders 5,6,7,8.
If the engine is rough then this pretty much confirms a misfire.
Have you cleared the codes and does the engine run smooth once codes cleared.
Old Aug 10, 2007 | 02:36 PM
87 XLT's Avatar
87 XLT
Lean misfire from a vacuum leak maybe?
Heres 2 of the pinpoint tests that I show for your missfire codes:
1 Vacuum leak in air intake system.
2 Fuel injector circuit malfunction.
Theres more, but these are the most likely considering what you have allready replaced or tested.
Have you checked for a vacuum leak on the intake runners for 1 & 8?
Old Aug 10, 2007 | 04:32 PM
FTE Ken's Avatar
FTE Ken
Moved to proper forum. (Your truck isn't a 2009 F150 Please double-check when posting.... thanks.
Edogrips
16
Aug 26, 2012 10:57 AM
j540john
May 21, 2011 10:32 PM
Pocket
39
Aug 18, 2008 02:40 AM
dave_1001
May 24, 2008 10:11 PM
captgarysr1
1997 - 2003 F150
Oct 8, 2005 07:28 AM
