2000 Explorer question?
Old Aug 10, 2007 | 07:57 AM
ExplorerMan02's Avatar
ExplorerMan02
My friend has a 2000 Explorer that won't run over 65mph. It is running rough, any ideas as to what to look at? It is the 4.0 OHV. Thanks
Old Aug 10, 2007 | 04:44 PM
steve(ill)'s Avatar
steve(ill)
is the check engine light on? you should be getting a code problem. go to auto Zone and have them scan the computer and see what it says. a good tune up with new plugs and wires could help. O2 sensor could be bad and wrong air-fuel ratio... i guess the muffler could be plugged and not letting flow thru, had to tell, need more data.
Old Aug 10, 2007 | 05:15 PM
marragtop's Avatar
marragtop
Pull the codes. There can be a code stored even if the CEL is out. Does it run the same when the engine is cold and warm?
