Aerostar Ford Aerostar
Slipping 2-3 shift
Old Aug 9, 2007 | 07:17 PM
Zen Punk's Avatar
Zen Punk
Slipping 2-3 shift
92 3.0 RWD
Can someone tell me the likely cause for the 2-3 shift to slip? If I keep constant acceleration, the engine will rev violently for a few seconds and then shift into 3rd at the shift point. If I let up on the throttle before the shift point, I can get it to shift much smoother, and I've been driving it like that for a while, but it's bothering me. The trans used to slip on every change when I got it, but I replaced the fluid & filter and modulator and now every shift is smooth except for 2-3. I haven't tightened the bands; are one of those involved in the 2-3 shift? Did I perhaps not seat the modulator correctly? Working space was tight because of the exhaust pipe/crossmember.
I appreciate any suggestions.
Old Aug 9, 2007 | 09:25 PM
96_4wdr's Avatar
96_4wdr
harsh 2>3 shift
http://autorepair.about.com/library/ts/at/bl-at-14.htm
soft or delayed 2>3 shift
http://autorepair.about.com/cs/troubleshooting/a/bl_45_at.htm
the A4LD has no EPC solenoid valve so scratch that one
modulator must be installed correctly or 1>2 shift would be harsh and late
probably your high-reverse clutch pack, valve body valve control for 2>3 shift or clutch pack piston seals
any particles, chunks in bottom of tranny pan when you changed ATF and filter?
Old Aug 9, 2007 | 09:34 PM
Zen Punk's Avatar
Zen Punk
I didn't notice any solid bits but there was a lot of thick black buildup on the bottom of the pan and sticking to the magnet. Should I try tightening the bands?
Old Aug 9, 2007 | 10:19 PM
96_4wdr's Avatar
96_4wdr
band adjusts not the problem
fairly easy is drop valve body, clean and check 2-3 Shift Valve; 2-3 Throttle Valve Modulator Valve for wear and dirt
Old Aug 10, 2007 | 11:35 AM
Zen Punk's Avatar
Zen Punk
You really think I could do that myself? I'm no transmission mechanic. Would it kill the trans to keep driving it as is?
78 & 87 Super Cab
Nov 8, 2013 09:44 PM
alchemist1
20
Mar 25, 2013 11:55 AM
walkee
15
Nov 16, 2011 08:30 AM
bgodkin
Nov 7, 2000 03:39 PM
