C6 shift points question
Old Nov 8, 2013 | 02:31 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Needing a little info here. The C6 in My '87 F250 is making the 1-2 shift @ 15 mph,and the 2-3 at 30 mph. Is this 2-3 shift point normal? I tried manual shifting, and the 2-3 came in @ 25 mph.
Also, My trans has a GearVendors unit on it.
Old Nov 8, 2013 | 08:51 PM
eakermeld's Avatar
eakermeld
I was just thinking about that today. My 89 has pretty much the same shift points. I have 3.55 gears so it lugs a lot if you let it. It only does it at lite acceleration. If you stand on it shifts at about 25 for 1-2 and 35 for 2-3. If I manual shift it i can wind it up to whatever I want. I'll have to look and see what controls this on mine. My dad had a 94 with 4.10 gears and it was about the same at lite throttle but wound up tight at hard throttle. Hope you get some good replies.
Old Nov 8, 2013 | 09:44 PM
78 & 87 Super Cab
I have 3.55's in Mine too, I have an adjustable vacuum modulator, but forgot which way to turn it. Trans doesn't slip at all, and has good red fluid
greenbeast1
May 6, 2014 11:16 AM
thekingofcows
Feb 8, 2011 12:31 PM
gstanfield
Nov 30, 2009 10:43 PM
Crumm
Oct 13, 2004 08:06 PM
bgodkin
Nov 7, 2000 03:39 PM
