Sponsored by: Real Truck
Part Identification
Old Aug 9, 2007 | 06:15 PM
FORDSDOWNER's Avatar
FORDSDOWNER
Part Identification
Could someone please help identify this part under the hood? It's on the passenger side just behind the battery.
What concerns me is that ocassionally, this thing makes noise while I'm waiting for the plugs to warm.
How much do shop manuals go for eh?
Chris-
2005 SD CC 6.0
Old Aug 9, 2007 | 06:43 PM
MAKO314's Avatar
MAKO314
that be the vacume pump, I think?
Old Aug 9, 2007 | 06:48 PM
Soilman's Avatar
Soilman
That's what I was going to say, the vacume pump. I never noticed before but it may be bringing the pressure up before you start like a fuel pump does?
Old Aug 9, 2007 | 07:02 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Just looked at www.motorcraft.com web site and the shop manual FCS1210705 retails for $185.00 and has 3000 pages.
Old Aug 9, 2007 | 08:50 PM
FORDSDOWNER
I guessed around that. Real proud of em I see. Thanks for finding it for me.
MAKO314, Soilman, Thanks on the response.
Chris-
2005 SD CC 6.0
Old Aug 10, 2007 | 03:13 PM
F250tuff's Avatar
F250tuff
A lot of people recommend http://www.helminc.com
Old Aug 10, 2007 | 04:07 PM
riggz's Avatar
riggz
I just noticed this the other day. I hear that thing humming constantly when I have the key in the On position before I start the truck. Should it ever shut off?
Old Aug 10, 2007 | 04:14 PM
Soilman's Avatar
Soilman
Does it shut off after the engine is running?
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Shop manual = helminc.com Helm has printed all the Ford manuals for decades.
faxonautolit.com New, used, reprinted manuals.
Old Aug 10, 2007 | 04:50 PM
bpounds's Avatar
bpounds
Mine shuts off after about a minute (guessing), but it does shut off. I assume when the vacuum level has reached a certain level?
Bill
Old Aug 10, 2007 | 08:57 PM
Soilman's Avatar
Soilman
As long as it cuts off you should be OK, if it ran on the whole time you got a vacuum leak.
Old Aug 15, 2007 | 09:09 AM
riggz's Avatar
riggz
Yeah mine is constantly running. I just noticed it about a week and a half ago. If I wiggle the unit it will stop as long as I am holding it in a tweaked position, but if I let go it will keep running.
Old Aug 15, 2007 | 03:38 PM
Soilman's Avatar
Soilman
Riggz, I am no expert on this topic by no means so you may want to go to the engine forum with this one, but I would say you got a vacuum leak that you are fixing and unfixing as you wiggle the pump. That means it is either the pump itself are one of the lines running out of it right at the pump. Should be easy to find and fix.
Old Aug 15, 2007 | 03:40 PM
riggz's Avatar
riggz
Yeah, I thought that would be the problem, but I wasn't able to duplicate it today. Maybe I was unknowingly plugging the inlet port. I'm going to check the ESOF solenoid as I have read here in another thread about those things leaking.
davewild
349
Aug 30, 2020 10:17 AM
cscott952
Mar 11, 2014 10:24 PM
chinofanta
May 9, 2013 11:10 AM
Longland
Oct 19, 2011 08:37 AM
FoPar1972
1997 - 2003 F150
Jul 23, 2011 09:51 PM
