Sponsored by: Real Truck
tranny need help
Old Aug 9, 2007 | 02:55 PM
bjis's Avatar
bjis
Question tranny need help
<TABLE><TBODY><TR><TD vAlign=top width="100%">Hey, I have a 2000 v10 4x4 with 114,000 miles or so. At 1800 to 2000 rpms i have a metal rattle it sounds like a heat shield but is not. If i remove the inspection plate on the tranny it gets louder. I think maybe torque converter but not for sure so HELP . Feels like lost power at low end torque and when i shift from gear to gear i get a loud thunk but u joints are good.Any ideas...... please help
</TD></TR></TBODY></TABLE>
Old Aug 11, 2007 | 07:21 PM
catmacanic's Avatar
catmacanic
Just for the 'hell of it'' check the 6 nuts convetor to flywheel, should be 35ft lb torque,
Old Aug 11, 2007 | 10:49 PM
ReAX's Avatar
ReAX
Also check the bolts bellhousing to engine and then check the fluid level. However, with the power loss, I think your T/C is on it's way out. The T/C multiplies torque and if fluid is bypassing it, it can feel like a power loss.
Old Aug 16, 2007 | 03:15 PM
bjis's Avatar
bjis
sorry it took so long to get back, the 6 bolts on the torque converter are good now for the torgue converter i need more time and money will it mess up the inside of the tranny
Old Aug 16, 2007 | 04:55 PM
catmacanic's Avatar
catmacanic
Cool
What I was trying to say is if the 6 bolts are loose you can get a rattle noise at certen engine speeds and load also a loose flywheel to crankshaft.If a convetor fails, rpm will be higher than normual under aceleration, watch your tack if rpm verys at hiway speeds it's the lock-up clutch. The only way to check ''how bad is it'' is drain trans oil, check magnet in pan and see how mush matteral is in pan and filter, well it hert it to drive? keep it to a minamum untill i'ts checked.
Old Aug 16, 2007 | 07:43 PM
bjis's Avatar
bjis
WOW need help , mercon v or mercon....... on a quart of mercon v atf it say for 1996 and up but all the books say mercon and do not use mercon v...... which one to use because i used mercon v a year ago on a fillter change ....all 17.7 quarts.....maybe the reason for all the problems
Old Aug 16, 2007 | 08:39 PM
ReAX's Avatar
ReAX
A/T - Mercon V ATF Usage
TSB
07/24/06
MERCON ATF IS BEING REPLACED BY MERCON V
ATF AS A SERVICE FLUID.
FORD:
1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1981-2004 E-Series, F-Super Duty
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1993-2004 F-53 Motorhome Chassis
1995-1998 Windstar
1997-2004 Expedition
2000-2005 Excursion
2001-2007 Escape
1987-2000 F-B-Series
2000-2007 F-650, F-750
LINCOLN:
1980-1997 Town Car
1981-1997 Continental
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY:
1980-1997 Grand Marquis
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR:
1985-1989 XR4TI
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE
MERCON(R) Automatic Transmission Fluid is being replaced by MERCON(R) V as a service fluid.
ACTION
Beginning immediately all automatic transmission / transaxle applications requiring MERCON(R) can now be serviced using MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V. After July 1, 2007, MERCON(R) Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCON(R) with MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V
cheese5.0
Mar 17, 2008 03:02 PM
Bowie
6.4L Power Stroke Diesel
Feb 27, 2008 07:16 PM
gsg1970
Mar 14, 2007 04:19 PM
lckleen11
Feb 14, 2007 09:31 PM
Clem B.
Offroad & 4x4
Jan 29, 2007 03:00 PM
