AOD / c6 Question
Old Aug 8, 2007 | 08:11 PM
onioncasserole's Avatar
onioncasserole
AOD / c6 Question
Which year model F 150 had an AOD Transmission? I know some had a c6 and some had an AOD. Where both transmissions used in the exact same models?
Thanks,
Jason
Old Aug 8, 2007 | 08:20 PM
mrl390's Avatar
mrl390
My 93 has the AOD.
Old Aug 8, 2007 | 08:25 PM
71ChargerRT's Avatar
71ChargerRT
My 90 F350 had an E4OD, and my 88 F250 has a C6, I know neither are are what you are asking for but...
Old Aug 8, 2007 | 08:33 PM
mrl390's Avatar
mrl390
Wikipedia (yeah i know it isnt very accurate) said that the C6 was used up until 96 in the f series trucks, but it doesnt say that the AOD was used in the f series trucks, even though I know I have one in mine.
Old Aug 8, 2007 | 08:42 PM
mrl390's Avatar
mrl390
I found more info. The AOD was used up until 93. Only used in F150 from 87-93. 92 and 93 have a beefed up version of the AOD.
Old Aug 8, 2007 | 11:23 PM
KDPate's Avatar
KDPate
My 88 has a C-6 in it....
Old Aug 9, 2007 | 05:49 AM
jroehl's Avatar
jroehl
My '90 had an AOD, and when I replaced that tranny, I got a used one out of an '89 F150.
Jason
Old Aug 9, 2007 | 06:45 AM
subford's Avatar
subford
My '83 has an AOD in it. Bought the truck new with one.
Old Aug 9, 2007 | 08:32 AM
RexB's Avatar
RexB
Here's a chart
https://www.ford-trucks.com/article/...ers_Guide.html
Old Aug 9, 2007 | 08:33 AM
RexB's Avatar
RexB
Here's a tranny chart
Old Aug 9, 2007 | 08:43 AM
Conanski's Avatar
Conanski
The AOD was found behind 5.0 motors in F150's & Broncos in the late '80s-early-90's. F250 and 5.8 trucks got the C6 before the E4OD was available.. somewhere around 1990. There was a ton of overlap with these trannys, but I think the AOD was mostly restricted to light duty 5.0 powered trucks.
Old Aug 9, 2007 | 08:48 AM
subford's Avatar
subford
Originally Posted by RexB
Your chart is wrong, the 1983 F150 also had the AOD.
Old Aug 9, 2007 | 09:05 AM
RexB's Avatar
RexB
It's a Ford-Trucks.com chart. You have the AOD, suggest a revision to Admin.
Old Aug 9, 2007 | 07:32 PM
mrl390's Avatar
mrl390
The chart says that the 81-83 pickups were f100s. I thought thats what they were in that year, but I have seen 83 pickups that are f150s. Was that a buffer year range or something? When did they officially change from f100s to f150s?
Old Aug 9, 2007 | 07:49 PM
subford's Avatar
subford
The salesman from FORD (a factory sale and not a dealer sale) that sold me my 1983 F150 new said that the F150 was a heavy half to get around some emission control and MPG requirements. He said that the lower rated 83 F100 were for the most part Computer Controlled and did not have a frame as heavy as the F150. In other words the F150 had a higher GVWR than the F100. The F150 also had heavier springs than the F100.
