code help
Old Aug 8, 2007 | 06:54 PM
R.E.M's Avatar
R.E.M
Cool code help
I posted this in my other thread also. po122, po562, p1280, p1393, p1744, p1780.what do these mean? If you read my other thread, you'll see what kind of problem I'm having. Thanks, Randy
Old Aug 8, 2007 | 07:37 PM
ryaneverk2's Avatar
ryaneverk2
P0122 Accelerator Pedal Sensor Circuit Low Input
P0562 System Voltage Low
P1280 ICP Circuit Out of Range Low
P1393 Glow Plug Circuit Low Input Bank No. 2 (Left
P1744 Torque Converter Clutch System Performance
P1780 TCS Circuit Out of self Test Range
Old Aug 8, 2007 | 08:23 PM
R.E.M's Avatar
R.E.M
could any of these cause my truck not to start?the batterys were about half charge. when he did the test.
Old Aug 9, 2007 | 06:03 AM
ryaneverk2's Avatar
ryaneverk2
Weak batteries can be a no-start culprit. They'll be strong enough to crank the engine, but not enough to fire the injectors and run the glow plugs and all that jazz.
Also, if the ICP sensor is bad, that can also be a no-start cause, sometimes. I'd make sure the batts are good and strong first, though.
Old Aug 9, 2007 | 09:07 PM
R.E.M's Avatar
R.E.M
what does ICP stand for and were is it located? Can't find it in my haynes manual.It won't crank with the batterys fully charge. Thats how much charge they had when he pulled the codes.Thanks
RKraft
Apr 1, 2013 03:53 PM
TWODOGS522001
Dec 4, 2012 08:34 PM
Holtian
Dec 18, 2009 02:25 PM
37 Ford guy
May 9, 2009 05:45 AM
glruff
Delaware Chapter
299
Jul 24, 2008 09:24 PM
