I posted this in my other thread also. po122, po562, p1280, p1393, p1744, p1780.what do these mean? If you read my other thread, you'll see what kind of problem I'm having. Thanks, Randy
P0122 Accelerator Pedal Sensor Circuit Low Input
P0562 System Voltage Low
P1280 ICP Circuit Out of Range Low
P1393 Glow Plug Circuit Low Input Bank No. 2 (Left
P1744 Torque Converter Clutch System Performance
P1780 TCS Circuit Out of self Test Range
Weak batteries can be a no-start culprit. They'll be strong enough to crank the engine, but not enough to fire the injectors and run the glow plugs and all that jazz.
Also, if the ICP sensor is bad, that can also be a no-start cause, sometimes. I'd make sure the batts are good and strong first, though.
what does ICP stand for and were is it located? Can't find it in my haynes manual.It won't crank with the batterys fully charge. Thats how much charge they had when he pulled the codes.Thanks
