Modular cam profiles ??
Old May 23, 2002 | 06:58 PM
Katmandu's Avatar
Katmandu
Anyone know where I can find the cam specs/profiles on the Modular engines ??
Thanks!
-ERIC
Old May 25, 2002 | 12:15 PM
MrBSS's Avatar
MrBSS
Yeah, its in the shop manual. Which, by the way, you must have if you're going inside your engine. I'll look it up for you if somebody doesn't post it soon.
Just out of curiosity, why do you care? If you want to know for rebuilding or just your personal knowledge, that's fine. (as an aside; "modular" is engineering-speak for "non-repairable sub-assembly"--you're supposed to replace the modules in case of fault, so I don't know what might be involved with getting into the heads).
If you're thinking of changing, you'd be best off to talk seriously to tech at one of the cam manufacturers (after checking to see if you have the PI heads). They would know any weak points for your application, and how to correct them (but don't forget: they want to sell you something!).
MrBSS
Old May 27, 2002 | 10:55 PM
Katmandu's Avatar
Katmandu
I really appreciate your input Mr.BSS.
I'm doing some research on possible mods for my 93 P71 (Crown Vic Police Interceptor).
Don't really have the fundage to do it with new parts, so I'm looking for "other sources".
Old May 30, 2002 | 08:12 PM
rosco351's Avatar
rosco351
Post Modular cam profiles ??
Old May 31, 2002 | 02:08 PM
MrBSS's Avatar
MrBSS
5.4: Cam lobe lift: exhaust 7.49744mm = 13.75 mm valve lift; intake 7.11038 mm = 13.01 mm valve lift
4.6: Cam lobe lift: exhaust 6.58939 mm = 12.0 mm valve lift; intake 6.58939 mm = 12.0 mm valve lift
Valve diameters are the same (~34mm exh, 44.5mm intake). They do not give degrees open or overlap. Source: Ford 2001 Workshop Manual. Hope this helps.
MrBSS
foofees
Nov 6, 2016 09:31 AM
jvandrehle
Modular V8 (4.6L, 5.4L)
Aug 26, 2012 08:03 PM
Dean88
16
Dec 5, 2007 02:15 PM
breakfree
Offroad & 4x4
Jun 11, 2006 04:47 PM
