vacuum help!
Old Aug 7, 2007 | 11:48 PM
Heff2727's Avatar
Heff2727
vacuum help!
does anyone have a vacuum diagram for a 1980 F150 351W? Im doing an engine swap and the new motor came with no vacuum lines whatsoever. Thanks guys.
Old Aug 8, 2007 | 08:36 AM
Franklin2's Avatar
Franklin2
In 1980, there was no 351w option in a truck. So you will never find a diagram for it. Where did the 351w come from? What are you taking out, a 302? You could take all the vacuum lines and switches carefully off the 302 and see if they will plug into the 351w carb if both engines had the motorcraft 2bbl.
Old Aug 16, 2007 | 11:20 PM
Heff2727's Avatar
Heff2727
The motor that im taking out is a stock 400 with motorcraft 2bbl, and all i know about the new motor is that the guy had it in a 87ish body style pickup and it originally came from a car i believe. It has a carter AFB carb, edelbrock performer intake, really loppy cam, 10:1 comp, a rebuilt distributor w/vacuum advance etc...but i would really appreciate it if one of you guys could help me out with running the vacuum for it. Just let me know any info you need and i have a few pics as well. Thanks guys.
Old Aug 17, 2007 | 01:50 AM
Sport45's Avatar
Sport45
Is the 351W already in? What transmission did you use?
Here is a link to some Ford vacuum diagrams. You'd have to know a little about the engine's original application to nail it down.
Old Aug 17, 2007 | 01:32 PM
Franklin2's Avatar
Franklin2
That engine is not stock at all. So I would not worry about any emissions vacuum lines. All you need to do is find a port in the rear to the hook the brake booster up, another port in the back in the manifold for the hose going to the manifold mounted on the firewall, and after you get it running, find a port on the carb that has no vacuum on it at idle, and does have vacuum when you rev the engine. This port will hook to the distributor vacuum. If it runs as rough as you say it does, you may not be able to find a port on the carb with no vacuum, since the idle will be turned up high to keep it running. So just pick one and hook it to the dist.
stevieray
17
Mar 22, 2011 10:42 PM
idahocrewcab
Jan 12, 2011 01:19 PM
Fasterhorses
1997 - 2003 F150
Jun 30, 2005 08:46 PM
kermit
Apr 18, 2004 11:35 PM
351 power
28
Jan 15, 2004 11:38 PM
