2150 ported vacuum
Old Nov 10, 2003 | 07:16 PM
351 power's Avatar
351 power
2150 ported vacuum
Which vacuum port is the right one for vacuum advance? Is it the one under the choke?
Old Nov 10, 2003 | 10:39 PM
LxMan1's Avatar
LxMan1
Yes, that is it.
Old Nov 11, 2003 | 06:26 AM
351 power's Avatar
351 power
Thanks. I posted a second related question in another forum, maybe you could say, do all vacuum advance canisters move the same amount?
Old Nov 11, 2003 | 11:24 AM
bubbaf250's Avatar
bubbaf250
There are several different OEM vac advance units, each with different calibration (vacuum sensitivity and advance movement).
To some extent, you can adjust the amount of advance with all of the adjustable vac advance units. All OEM Ford vac advance units made since the late '60s are adjustable. There are also aftermarket adjustable vac advance units with various specs.
Here's some more info about adjusting (tuning) the vac advance:
http://home.earthlink.net/~bubbaf250/perf/perf02c.html
Old Nov 13, 2003 | 10:24 AM
351 power's Avatar
351 power
Should an engine block retain the vacuum advance canister from its original year of manufacture/distributor type, or should it use the canister from the distributor type that isn't original? The canister from 88 seems to have more range of movement.
Old Nov 13, 2003 | 03:45 PM
JoeBlow's Avatar
JoeBlow
I don't want to hijack this thread, but on my 2150 the ported vacuum line is T'ed off. ?One end goes to the vacuum advance and the other to the back of the carb to the egr? Is this right?
BTW thanks Bubba for the great links. When are you going to get around to giving directions on how to rebuild this carb?
Old Nov 13, 2003 | 05:29 PM
LxMan1's Avatar
LxMan1
This is correct only if the EGR line goes thru a temp operated vacuum switch first so that it doesn't open when the engine is cold.
Jimmy
Old Nov 13, 2003 | 07:09 PM
JoeBlow's Avatar
JoeBlow
It goes straight into the egr. nothing in between. The truck runs great until it gets warm. The choke wont open up an its own and when i open it maunally, it bogs the engine down.
Again I want to apoligize if you feel that i am hijacking this thread. It is just that i was going to ask about this today as well.
sorry
Old Nov 13, 2003 | 07:43 PM
LxMan1's Avatar
LxMan1
It sounds like you have a vacuum leak somewhere, carb gasket or intake gaskets.
Jimmy
Old Nov 13, 2003 | 08:07 PM
bubbaf250's Avatar
bubbaf250
The ignition calibrations (including vac advance) were specific to the engine/application. So, if you want OEM stock-type performance, you should use the original vac advance unit specified for that engine in that vehicle.
Using a different vac advance unit might give better-than-stock performance. Either way, it will take some trial and error testing to get it right, or a tuning shop with a distributor machine to dial it in for you.
Old Nov 13, 2003 | 08:30 PM
JoeBlow's Avatar
JoeBlow
I just noticed i am missing one of the screws that hold down the top of the carb. While the tops seems plenty tight, could this be a possible source of my problem?
Old Nov 13, 2003 | 11:40 PM
bubbaf250's Avatar
bubbaf250
No. The engine will run fine with the top completely off the carb, though you wouldn't want to drive it that way.
The main problem with a missing screw on the top is that the top will eventually warp because the pressure holding it against the gasket isn't distributed properly.
You could have fuel leaks, if the screw is missing from one of the front four positions. And if it's missing from one of the rear positions, the carb could suck in unfiltered air below the air filter housing.
A vacuum leak is somewhere below the throttle plates.
Old Nov 14, 2003 | 08:52 AM
JoeBlow's Avatar
JoeBlow
I got some carb cleaner and pretty muchsoaked the carb and intake with it and nothing happened. The idle didn't change at all.
runs fine when cold, but when it warms up and I manually open up the choke it starts running rough and dies under load. not while in park or neutral. only when it is in gear. Could this be EGR?
Old Nov 14, 2003 | 10:11 AM
bubbaf250's Avatar
bubbaf250
It could be EGR, but I think the symptom still points to a vacuum leak.
Have you checked all of the vacuum hoses for leaks? Any loose hoses that should be plugged or re-connected?
How about all of the diaphragms attached to vacuum hoses (vac advance, EGR valve, heat stove vac motor in the air cleaner housing snout, etc.)?
How about any other vacuum devices (switches, delay valves, bleed valves, reservoirs, etc.)?
How about all of the hose junctions (T connectors, Y connectors, etc.)?
How about the rubber caps that block off on any unused vacuum nipples on the main manifold vacuum tree?
After you check all of those things, then you should start looking elsewhere.
Old Nov 14, 2003 | 11:00 AM
JoeBlow's Avatar
JoeBlow
Just took yet another look at it. If the port under the choke is ported vacuum and it supplies vacuum to the vacuum advance, when I feel it with the engine running shouldn't I feel suction?
